small problem in sdk with unistd.h and closesocket()
kas1e
Post by kas1e »
Hi
Have found for now a small problem in SDK, which easy to reproduce. The problem happens _ONLY_ when uses __USE_ONLINE__ . The code for reproduce:
#include <proto/socket.h>  // or for example <proto/bsdsocket.h> will give the same
#include <unistd.h>
test()
closesocket(NULL);
Then just try to make an object , like:
ppc-amigaos-gcc -D__USE_INLINE -c test.c
Or via ppc-amigaos-g++ , does not matter. And it will give you in result such bunch of errors:
In file included from /usr/local/amiga/ppc-amigaos/SDK/newlib/include/unistd.h:4,
                 from closesocket.c:2:
/usr/local/amiga/ppc-amigaos/SDK/newlib/include/sys/unistd.h:96:33: error: macro "getdtablesize" passed 1 arguments, but takes just 0
/usr/local/amiga/ppc-amigaos/SDK/newlib/include/sys/unistd.h:98: error: expected '=', ',', ';', 'asm' or '__attribute__' before '->' token
Then, just swap in the test-example includes, and put <unistd.h> at top, but <proto/socket.h> or <proto/bsdsocket.h> at bottom, to have in end such test case:
#include <unistd.h>
test()
closesocket(NULL);
And try again to compile an object by ppc-amigaos-gcc -D__USE_INLINE__ , and you will see that there is no warnings, and object compiles fine.
Without __USE_INLINE__ no errors at all. They happens only with __USE_INLINE__ provided, and only when including of socket's protos are at top.
Of course, one can say something like "plz, unistd.h firstly all the time" , but, as i see in all the sources of many projects, and from all my past expirience, its all not so matter will i put it at top, or at bottom. Includes imho should worry about such kind of stuff, and parse it correctly (and as i say without __USE_INLINE__ test case works in any orders, be unistd.h at top, or at bottom, not so matter).
Can someone from core-devs check this out and fix ?
Thanks for
