Is libInit() protected from switching i.e not running multitask
gdridi
Post by gdridi »
Hello!
I see difference between running my library between AOS4.1FinalEditionUpdate0 and AOS4.1FEUpdate2
Is there a Forbid() done by the Kernel when libInit() is called to initialize library code ? That was removed in AOS4.1FinalEditionUpdate2 ?
This leads to instability when launching multiple instances of my library at the same time. So libInit() must be protected by a Forbid().
This could explain mysterious bug ?
When launching multiple instances of program in parallel that use a same library.
Sincerely yours,
DGILLES
Hypex
Re: Is libInit() protected from switching i.e not running multitask
Post by Hypex »
I don't see any indication from OS3 or OS4 documentation you need to isolate the libInit() in a Forbid()/Permit() lock. It's possible there was a change in kernel routines that has the side effect of causing instability. However, if your library is having issues with parallelism, it might be a good idea to protect the libInit() routine regardless. This need not be a classic Forbid()/Permit() lock frowned upon. This could be a semaphore, but a semaphore has the same locking issue, since internally it's managed by another Forbid()/Permit() lock. So a mutex might be a better idea in this case for OS4 native code.
gdridi
Post by gdridi »
Thank you Hypex!
That’s what I do (mutex for open() and another for close() - should be the same mutex? )
Mutex is not strictly a binary semaphore (no wait() function implies, so mutex could work with multicore).
DGILLES - Arabic console os4depot.net -
