Rollover keyboard faulty
gdridi
Post by gdridi »
Hello!
I use a DELL - DELL USB Keyboard - multi-classe
Model SK-8115
On my SAM440ep with FEu0 rollover works good that is pushing rapidly three keys of the keyboard on the Shell for instance : UYT displays uyt.
But on my A1222+ it displays a character ‘y’ more uyty.
I tried input prefs repetition or delay without success.
It appears when typing into the Shell also.
Have idea?
DGILLES
gdridi
Re: Rollover keyboard faulty
Post by gdridi »
Hello!
No one notice this bug on A1222+
Enhancer and V54 packs installed.
Rollover faulty ; even I ´m not Lucky luck ! It is noticeable ?
Sincerely your,
DGILLES
Rigo
Post by Rigo »
Personally, I would suggest to uninstall any "enhancer" software first, and rerun your tests.
IF there is a bug, eliminate as many variables as you can.
It has been proven in the past that the "enhancer" is not quite the enhancement you think it might be...
Simon
