How to change LF to CRLF in the input? Prefs? [solved]
gdridi
Post by gdridi »
Hello!
Is there a option to change LF to CRLF in the input?
Or somewhere else..
I need to disable LF=CRLF because it seems to be "the bug" in my program : always ok for the first line but second line becomes reversed ; all lines are ASCII with an ESC starting.
DGILLES - Arabic console os4depot.net @ 30 May 2024 -
Re: How to change LF to CRLF in the input? Prefs?
Is this the problem you showed in the thread "Console.device A1222..." ?
If so, please email me privately so that we can sort out the problem.
gdridi
Re: How to change LF to CRLF in the input? Prefs? [solved]
Post by gdridi »
Hello!
After talking with Tonyw
The misoperating was due to not taking into account multiline in FEu2 or FEa1222, like "abc\ndef" as one string received instead of two strings "abc\n" and "def", with previous venerable FEu0
Wow
DGILLES - os4depot.net @ 25 June 2024
