A1222+ AmigaOS or Update 2 trouble [solved]
gdridi
Post by gdridi »
Hello !
It seems, I do something wrong in this peace of code:
my_screen = IIntuition->OpenScreenTags(NULL,
    SA_Title, "Arabe : Normal",
         SA_Pens, (ULONG) pens,
         SA_Depth, 1,	// 1.2.3.4!		// look also to SetAPen() Depth fourth(4) needs more than a SetBPen, a better colormap to handle cursor COMPLEMENT
         TAG_DONE);
I launch my program from a shell and the screen titled: "Arabe : Normal" won’t appeared (no screen appears).
I use the A1222+
My compiled code is from a SAMEP AOSFE update 0 SDK 5x and it worked on my SAM.
Some ideas? Perhaps the depth = 1 is to small ??
DGILLES - os4depot.net - 1st of April 2024
Re: A1222+ AmigaOS or Update 2 trouble
Post by thomasrapp »
// tester my_screen à NULL
Did you do what the comment says? And what is the result? Did you get a NULL pointer, i.e. opening the screen failed? Or did you get a pointer to an invisible screen?
Please also show how you define "pens" where SA_Pens points to.
I guess it tries to default to an AGA native screen mode but native chipset is not available. Try to add SA_LikeWorkbench,TRUE to point it to the same monitor as the Workbench screen. Or add SA_DisplayID with a valid screen mode.
And next time please make a better thread title. Your problem surely has nothing to do with the A1222 and you don't have trouble updating it.
gdridi
Post by gdridi »
@Thomas
Thanks to you, I progress and found that:
UWORD pens[] = { ~0 };
         SA_Depth, 1,
         TAG_DONE);
This code crashes on my AOSFE on A1222+
I know because when I add "SA_LikeWorkbench, TRUE," it did not crash.
And when I used SA_DisplayID instead of SA_LikeWorkbench it crashes too.
Normally, the code above should work.
Would someone like to try on AOSFE for A1222+
Thanks Thomas who found the bug.
Now, I think that perhaps my monitor (device) named Radeon in devs/monitors has ToolTypes not well defined.
Only 320x250@60D (yes 60D)
320x256@60D
Exists
Help appreciated
gdridi
Re: A1222+ AmigaOS or Update 2 trouble [solved]
Post by gdridi »
Yes!
It was on the tool types of tab ´icon’ of my Radeon monitor (devs/Monitors).
Comment this line with parenthesis:
(DISABLEFAKENATIVE=Yes)
Another thing!
With AOS4.1FEa1222 someone can not quit the editors correctly (don’t know why).
For instance: when using the "s:scripted" script to launch the two editors (stevie and ed).
Debug info says : "BeginIO in arabicconsole.device" but I’m quitting!
But It works on my SAM440ep with AOS4.1FEu0
DGILLES - console ArabSCII - os4depot.net - 1st of April 2024
