BrassMonkey
BrassMonkey
Wicknix has released the new BrassMonkey Internet Suite. It contains a web browser, email client, HTML editor, IRC client, News client and RSS client.
Further information: github.com
I compiled it for Linux PPC 32-bit without AltiVec support. It works on Void PPC, MintPPC, Fienix, Debian etc.
.mozconfig
export CC="gcc -m32"
export CXX="g++ -m32"
mk_add_options PYTHON=/usr/bin/python2
mk_add_options AUTOCONF=/usr/bin/autoconf-2.13
# Set GTK Version to 2 or 3
_GTK_VERSION=2
ac_add_options --target=powerpc-linux-gnu
ac_add_options --host=powerpc-linux-gnu
ac_add_options --with-system-jpeg
ac_add_options --enable-application=suite
ac_add_options --enable-jxl
ac_add_options --enable-strip
ac_add_options --enable-default-toolkit=cairo-gtk2
ac_add_options --disable-devtools
ac_add_options --disable-gconf
ac_add_options --disable-precompiled-startupcache
export MOZ_TELEMETRY_REPORTING=0
export MOZ_ADDON_SIGNING=0
export MOZ_REQUIRE_SIGNING=0
Download: brassmonkey-32.5.0.linux-powerpc.tar.bz2
Re: BrassMonkey
There is a package extras.zip with add-ons and themes.
You can install for example greasemonkey.xpi for using YouTube in HD with ViewTube.
You can also install uBlock0rigin.xpi for faster surfing by blocking adverts and web tracking.
Re: BrassMonkey
I compiled BrassMonkey 32.5.1 with the new Goanna layout and rendering engine 6.6.0 for PPC64 with AltiVec support today. It contains a web browser, email client, HTML editor, IRC client, News client and RSS client.
Compile time on an X1000: 368:00.12
Download: brassmonkey-32.5.1.linux-powerpc64-gtk2-altivec.tar.xz
Re: BrassMonkey
I compiled a 32-bit PowerPC version without AltiVec today.
Compile time on an X5000/40: 133:34.41
Download: brassmonkey-32.5.1.linux-powerpc-gtk2-without_altivec.tar.xz
Re: BrassMonkey
Wicknix has released BrassMonkey 33.4.0. Unfortunately the mail component is broken due to new commits.
Compile time on an X5000/40: 133:17.89
./mach package
/home/amigaone/Downloads/brass-monkey-33.4.0/obj-powerpc-linux-gnu/suite/installer/package-manifest:57: Missing file(s): bin/icudt63l.dat
Solution:
cp /home/amigaone/brassmonkey/icudt63l.dat obj-powerpc-linux-gnu/dist/bin/
After starting the mail component:
XML Parsing Error: undefined entity
Location: chrome://messenger/content/msgAccountCentral.xul
Line Number 156, Column 11:          <label class="acctCentralText"
There was a commit 10 months ago. I have tried the commit before and it works again.
vim platform/mailnews/base/content/msgAccountCentral.xul
Link: msgAccountCentral.xul
./mach build again.
./mach run
./mach package
The icudt63b.dat is missing in the package. Please extract the package in obj-powerpc-linux-gnu/dist and copy the icudt63b.dat to the brassmonkey directory.
Download: brassmonkey-33.4.0.linux-powerpc-gtk2-without_altivec.tar.xz
Another issue after testing:
Menu Edit - Mail & Newsgroups Account Settings...
Output:
Location: chrome://messenger/content/AccountManager.xul
Line Number 38, Column 7:      <button id="accountActionsButton" type="menu"
sailorMH
Re: BrassMonkey
Post by sailorMH »
I tried BrassMonkey 32.5.1 with altivec on X1000 + Debian Sid.
With this result:
./brassmonkey
XPCOMGlueLoad error for file /home/martina/brassmonkey/libxul.so:
libffi.so.6: cannot open shared object file: No such file or directory
Couldn't load XPCOM.
I simply extracted archive to home folder. Please, which is right way to run Brassmonkey?
Re: BrassMonkey
sailorMH wrote: Fri Nov 15, 2024 8:56 pm I tried BrassMonkey 32.5.1 with altivec on X1000 + Debian Sid.
With this result:
./brassmonkey
I uploaded the libffi.so.6 for PPC64 today.
Link: libffi.so.6.suse-ppc64.gz
Please copy it to /lib64.
# cp libffi.so.6.suse-ppc64 /lib64/libffi.so.6
After that try to start BrassMonkey again.
Re: BrassMonkey
I replaced some files with the ones from November 2023 (UXP-RB_20231128) and added the calendar additionally.
[amigaone@void-ppc base]$ cp -R ../../../../uxp/mailnews/base/content .
[amigaone@void-ppc prefs]$ cp -R ../../../../../uxp/mailnews/base/prefs/content .
[amigaone@void-ppc mailnews]$ cp ../../../uxp/mailnews/jar.mn .
ac_add_options --enable-calendar (You have to add Lightning from the extension directory - File - Open File...)
New download: brassmonkey-33.4.0.linux-powerpc-gtk2-without_altivec.tar.xz
Screenshot of BrassMonkey 33.4.0 with Netscape 7 logo:
For Fienix:
You need libffi7 and libjpeg8 for BrassMonkey on Fienix.
You can install them with the following commands:
fienix@fienix:~/Downloads/sealion$ sudo apt-get install libffi7
fienix@fienix:~/Downloads/sealion$ sudo apt-get install libjpeg8
sailorMH
Re: BrassMonkey
Post by sailorMH »
Thank you!
With Debian 8 libffi.so.6 should be copied to /usr/lib/powerpc-64-linux-gnu.
Allworks very nice!!
EDIT:
P.S.: compile time at X1000: 368:00.12 is 368 minutes?
Re: BrassMonkey
sailorMH wrote: Sat Nov 16, 2024 2:58 pm P.S.: compile time at X1000: 368:00.12 is 368 minutes?
Great! That it works. Yes, 368 minutes.
