I don't use Move very much, but am taking a look at it for a script I'm building. According to the docs, "If you name a destination directory that does not exist, MOVE will create a directory with that name." Either I'm doing it worng, or its not functioning as intended.
move temp:foo.txt to misc:bar
How do I move a file, create a target directory that doesn't exist, and keep the original name?
