Wicknix has updated the old SpiderWeb with the latest UXP. He changed the name, icons, etc for a fresh look and feel.
Download: sealion-32.1.1.linux-powerpc-gtk2.tar.bz2
Further information: https://github.com/wicknix/SeaLion
FYI: SeaLion needs the libjpeg.so.8. This lib isn't available on new Debian based distributions (MintPPC, Debian Sid, etc). I uploaded it.
Download: libjpeg.so.8
Please copy it to /lib/powerpc-linux-gnu as root. After that run the command ldconfig for adding the new lib to the library cache. Then close the terminal and try to start SeaLion again.
Wicknix has released SeaLion 32.2.0. :-)
This is a fantastic browser because of a fast and great old user interface with the latest Goanna layout and rendering engine. :-)
YouTube videos in HD with ViewTube and SeaLion
Here are installation instructions for ViewTube with SeaLion:
  1. Download the SeaLion-Extras.zip package.
  2. Unpack it and install the addon greasemonkey-3.10.0.1rc3pre-sw.xpi
  3. Download the ViewTube SeaLion package
  4. Unpack the package and copy the folder gm_scripts to /home/<your user directory>/.wicknix/sealion/<profile directory>/
    For example:
    cp -R Downloads/ViewTube_SeaLion/gm_scripts /home/amigaone/.wicknix/sealion/iykmgak4.default/
  5. Restart SeaLion
If you use Fienix, MintPPC and Debian and you need some old libraries then install them from the following package.
Wicknix wrote: I uploaded libffi and libjpeg from Void to the releases page. Let me know if Debian/Fienix/Mint require any others. Thanks.
sl-ppc32linux-libs.tar.bz2
xeno74 wrote: Mon May 15, 2023 10:22 am Image
    For example:
  5. Restart SeaLion
You need to configure ViewTube via the 3 dots under the video. I use the embed video with Embed and play it with VLC.
sailorMH
Post by sailorMH »
I want to test last SeaLion, but it is 32-bit, and Debian Sid is 64-bit release.
Is possible to add 32-bit architecture to system with dpkg --add-architecture powerpc?
Works this today? Or is some simpler way?
I cannot create a mess in my fresh Debian system installed from scratch ;-)
sailorMH wrote: Tue May 23, 2023 6:55 pm I want to test last SeaLion, but it is 32-bit, and Debian Sid is 64-bit release.
Please try to install the package libc6-powerpc
GNU C Library: 32bit powerpc shared libraries for ppc64
This package includes shared versions of the standard C library and the standard math library, as well as many others. This is the 32bit version of the library, meant for ppc64 systems.
I think you need to install other libraries additionally.
I don’t have any experiences with 32-bit libraries on a Debian 64-bit userland so you are the first one who eventually test it.
I created a Chroot for using an other distribution in a main distribution additionally a few years ago.
