Fienix 6.1
Fienix 6.1
Hi . Downloaded fienix 6.1 to usb . Used boot commands from Skateman. The line with,,fatload usb 0:1 1d00000 cyrus-p5020.dtb. Bootm-1000000 -1d00000, of with the uImage-6.1 line also. So thank you. The question is do you partition the ssd or use whole ssd ( I have a 1 terabyte ssd) .thank you
Re: Fienix 6.1
If you use the installer, then you can only select a whole disk (e.g. SSD).Tijatjj wrote: Wed Apr 12, 2023 4:41 pm The question is do you partition the ssd or use whole ssd ( I have a 1 terabyte ssd) .thank you
Re: Fienix 6.1
Ok thanks. Just for argument sake would it be easier to get a smaller ssd , what would be reasonable. Mainly because it seems to be taking forever
Re: Fienix 6.1
Hi , ok so it looks like it’s doing the blinking light thing like nbache had problems with .using an Radeon sff 7750 1 gig. If i download just the image without installer what size partition would I use just for the fienix 6.1 in x5000.so as to get it up and running, thank you
Re: Fienix 6.1
I would recommend an 80 GB partition. At least 20 GB.
Roland wrote: Tue Mar 07, 2023 7:41 pm Got it running finally! But I had to use an external disk unit as an intermediary: create a huge 20 GB partition, ...
Re: Fienix 6.1
Hi , ok thanks you are the man . Anytime anywhere you have always answered thank you .
