Fienix 6.1 ?
Tijatjj
Fienix 6.1 ?
Post by Tijatjj »
Usb fienix- installer login . Anyone know what this means. Got it after booting from usb thanks
Re: Fienix 6.1 ?
You could try to login:
Username:fienix
Password:fienixPW
I think you have the USB Installer which is used to install Fienix on a HD
Tijatjj
Re: Fienix 6.1 ?
Post by Tijatjj »
Hi thanks for the reply. Oh so you use this usb to install on ssd. Would you be able to install that from command line or need to use another Linux distro, thanks
