Fienix boot command usb
Tijatjj
Post by Tijatjj »
Hi what are the boot commands for usb stick for fienix 6.01, thanks
Re: Fienix boot command usb
For X5000/20:
usb reset
setenv bootargs root=/dev/sdb2 rootdelay=5
fatload usb 0:1 1000000 uImage-6.1
fatload usb 0:1 2000000 cyrus-p5020.dtb
bootm 1000000 - 2000000
The "/dev/sdb2" might be "/dev/sdc2" if you already have another USB drive plugged in.
Please Note: If you use an uInitrd for example for booting with a LABEL, then load the dtb file to the address 1d00000. The kernel has grown in recent months so the address 1c00000 is used by the uImage. Before we have loaded the dtb to the address 1c00000.
X5000> bootm 1000000 2000000 1d00000
