fienix 6.1 /cub install
Tijatjj
Post by Tijatjj »
hi,looking to install on a x5000 ssd.can i use windows to do this or do i need a linux machine ,thank you
Re: fienix 6.1 /cub install
Tijatjj wrote: Sun Mar 26, 2023 1:46 am hi,looking to install on a x5000 ssd.can i use windows to do this or do i need a linux machine ,thank you
Yes, it is possible to copy it with Windows to a SSD. You need to connect the SSD via USB adapter to Windows.
Instructions
  1. Download "USB Image Tool" from alexpage.de
  2. Open USB Image Tool
  3. On the left panel, select your USB disk
  4. Click the "Restore" button and select the Fienix disk image
Tijatjj
Post by Tijatjj »
Ok thank you. Also what are the boot args for the ssd , thanks again
For example for sata 0:1:
  1. Code: Select all
    X5000> setenv bootargs root=/dev/<your partition/block device id>
    For example:
    X5000> setenv bootargs root=/dev/sda4
  2. Code: Select all
    X5000> load sata 0:1 1000000 uImage-6.1
  3. X5000/20:
    X5000> load sata 0:1 2000000 cyrus-p5020.dtb
    X5000/40:
    X5000> load sata 0:1 2000000 cyrus-p5040.dtb
  4. Code: Select all
    X5000> bootm 1000000 - 2000000
