Partially selected state for checkbox.gadget
The Checkbox ReAction gadget could benefit from a "partially selected state". This is the state used to indicate that the children have some, but not all, items selected. It is usually depicted in other operating systems as a dot or square. The user themselves won't be able to pick this, it will only be available to set and read programmatically. If the user clicks on a partially selected checkbox it will change to a fully selected one.
Currently checkbox gadgets cannot display this state and have to pick between checked or unchecked, which can be misleading.
listbrowser.gadget suffers from this when hierarchical and checkboxes are set, as partial selections further down the tree can't be indicated at the top level.
There is not even an appropriate glyph.image built-in to use for this with a custom button.
amifrog
Re: Partially selected state for checkbox.gadget
Post by amifrog »
sounds usefull.
trixie
Post by trixie »
@chris
Don't know if it helps you but the tickbox.gadget from the Enhancer class set has this feature. I know because I implemented it :-) I'll be happy to add it to the system checkbox as soon as the lawsuit is over and OS4 development restarts.
The Rear Window blog
trixie wrote: Tue Mar 07, 2023 3:30 pm @chris
Hmm, possibly, although the Autodoc on the wiki doesn't appear to mention this? http://wiki.amiga.org/index.php?title=T ... dget_Class
trixie
Post by trixie »
@chris
It doesn't, but the autodoc that comes with the Enhancer SDK certainly does. The SDK also contains an example demonstrating the use of the feature.
