Mighty Mike (a.k.a. Power Pete)
I was able to compile Pangea's Mighty Mike on MintPPC and Void PPC yesterday. It works but there are wrong colors with the GL renderer.
Maybe an endian issue?
The colors are correct without the GL renderer but the game is slow without it.
Further information about Mighty Mike: https://jorio.itch.io/mightymike
I created a bug report yesterday. Link: Linux PPC: wrong colors with the GL renderer
Re: Mighty Mike (a.k.a. Power Pete)
Jorio replied to our bug report yesterday.
jorio wrote: It looks like __BIG_ENDIAN__ is correctly set, otherwise you wouldn't have been able to get this far into the game.
Try to change GLRender.c:54 to:
#define kFramePixelType GL_UNSIGNED_SHORT_5_6_5_REV
I compiled it with his modification today.
/home/amigaone/Downloads/MightyMike/src/Drivers/GLRender.c:54: warning: "kFramePixelType" redefined
   54 |  #define kFramePixelType   GL_UNSIGNED_SHORT_5_6_5_REV
/home/amigaone/Downloads/MightyMike/src/Drivers/GLRender.c:46: note: this is the location of the previous definition
   46 | #define kFramePixelType GL_UNSIGNED_SHORT_5_6_5
Unfortunately it doesn't start.
Output:
EE ../src/gallium/drivers/r600/r600_asm.c:2691 r600_vertex_data_type - unsupported vertex format PIPE_FORMAT_R5G6B5_UNORM
Success! Jorio has posted a solution! :-)
Jorio wrote: Revert to GL_UNSIGNED_SHORT_5_6_5 and try this instead:
Palette.c:241:
color16 = ((blue >> 3) << 11) | ((green >> 2) << 5) | (red >> 3);
Jorio wrote: FramebufferFilter.c:53:
*color = ((bmix8 >> 3) << 11) | ((gmix8 >> 2) << 5) | (rmix8 >> 3);
It works with the correct colors! :-)
Download for Linux PPC 32-bit without AltiVec: MightyMike_3.0.2-linux-powerpc.tar.gz
It works with Void PPC, MintPPC, Fienix, Debian Sid etc.
