UHCI controller bailing out
OldFart
Post by OldFart »
Of late I have the experience that the UHCI controller gives problems. A requester shows up with the message: "There are unresolvable problems with UHCI controller". The options are "Reset controller" and "Stop controller".
This occurs after having installed upd 3. System to which applied is a standard µA1 with only a Tekram SCSI-controller installed as modification, besides a disabling of the rear USB ports.
Clicking either option of the requester does not seem to solve any problem ("does not do anything").
No matter what (storage-)device I have plugged in to the USB port.
OldFart
X5000, appears to be sick. Dismantled jan 1, 2024.
Dead MicroA1
RaspBerry Pi 2B, 3B, 4B/4Gb, 4B/8Gb
OrangePi 5+ 8Gb
ACER Windows 10
mechanic
Re: UHCI controller bailing out
Post by mechanic »
No uA1 here.
I believe the uA1 is UHCI only so the OHCI and EHCI kickstart modules should not be loaded.
Have you tried - USBctrl restart - in a shell?
