Hello All,
In 2021, I was working on my A1200 for AmiWest and the system still has the problem. What problem? AmigaOS 3.2 installed, latest MMULibs from AmiNet installed (From 2023-01-09), Blizzard 1260 with 128 MB installed, and if I boot with "setpatch :NIL<>" assign crashes at startup, with "setpatch nocache :NIL<>" system boots and runs normally.
I've tried with the Blizzard1260 jumper in both states, same problem.
I'd love to gain the performance from the CPU cache. Open to suggestions on what's going on.
Thanks!
Bill "tekmage" Borsari
Blizzard 1260 and CPU Cache
my_pc_is_amiga
Re: Blizzard 1260 and CPU Cache
I don't have a 1260 but I'm attaching the MMU config. file that I'm using for a CSPPC. I'm wondering if in your config. if there is a P5Init or not. Also, what is your listing of the libs:680#?
;** MMU Configuration file **
;** this file is read on startup by the mmu.library and used to modify **
;** the pre-calculated or scanned MMU table **
;** © 1999-2021 THOR Software, Thomas Richter **
; the current version of the MMU library knows six commands that can
; be used in this file:
; CLEARTTX clears all or parts of the transparent translation registers
; ADDMEM adds memory to the exec free list pool. BE WARNED, this command
; does NOT modify the MMU tables, this must be done by yourself
; SETCACHEMODE defines the MMU tables.
; DESCRIPTORCACHEINHIBIT defines whether the data cache should be disabled
; for the MMU descriptors. It's usually OFF meaning the cache will
; remain enabled. This is fine for the mmu.library, but certain
; hacks might require a ON argument here. Note that this means more
; work for the library.
; FOR executes a command only for a specific hardware expansion which is
; given by the manufacturer and product ID.
; CLEARMMU overrides the MMU configuration found by the library for selected
; parts of the configuration.
; All other commands are currently "external". The library will scan for
; these commands in "LIBS:mmu" and execute them on startup. These *are not*
; standard shell commands. They cannot be run from the shell, and shell
; commands cannot be started from this file.
ClearTTx ;ignore all TTX registers if any. We don't need them.
;this will speed up the system for some machines.
; Remove the semicolon in the line below if you have to live with other MMU
; hacks that expect the MMU descriptors in non-cacheable memory. This is by
; default OFF, i.e. descriptors will be cachable.
; The library will work fine and will take all precautions for descriptors
; in the cache, but some third-party hacks might not.
;DescriptorCacheInhibit ON
; Remove the semicolon in the two lines below in case you encounter hangs or
; crashes with Zorro-II 16-Bit memory. It will disable caching for the Z-II
; area. Clearly, this is slower, but it will work, at least.
;Z2Burst off
; The following lines are strictly speaking not necessary.
; They will change and optimize the caching mode for graphics boards,
; but it will also work without them.
; The Picasso96 software will also optimize the MMU caching mode itself
; and therefore makes the following completely superfluous.
; CyberGraphics does not take these steps and might profit from the
; following.
; To speedup booting, you may remove all the lines of the boards
; you do not own.
; Altais
For 18260 19 SetCacheMode {base} {size} CacheInhibit NonSerial Imprecise
;Retina Z3
For 18260 16 Z3 SetCacheMode {base+0x00c00000} 0x00400000 CacheInhibit NonSerial Imprecise
;Merlin
For 2117 3 Z3 SetCacheMode {base+0x00c00000} 0x00400000 CacheInhibit NonSerial Imprecise
For 2117 3 Z2 SetCacheMode {base} {size} CacheInhibit NonSerial Imprecise
;oMniBus, Size > 0x00100000
For 2181 0 BIG SetCacheMode {base+0x00c00000} 0x00200000 CacheInhibit NonSerial Imprecise
;Graffity Z2
For 2092 33 Z2 SetCacheMode {base} {size} CacheInhibit NonSerial Imprecise
;Graffity Z3
For 2092 33 Z3 SetCacheMode {base+0x00c00000} 0x00200000 CacheInhibit NonSerial Imprecise
;Domino
For 2167 1 Z2 SetCacheMode {base} {size} CacheInhibit NonSerial Imprecise
;PicassoII
For 2167 11 SetCacheMode {base} {size} CacheInhibit NonSerial Imprecise
;GVP Spectrum
For 2193 1 SetCacheMode {base} {size} CacheInhibit NonSerial Imprecise
;Piccolo
For 2195 5 SetCacheMode {base} {size} CacheInhibit NonSerial Imprecise
;Piccolo-SD64 Z2
For 2195 10 Z2 SetCacheMode {base} {size} CacheInhibit NonSerial Imprecise
;Piccolo-SD64 Z3
For 2195 10 Z3 SetCacheMode {base} 0x00400000 CacheInhibit NonSerial Imprecise
;VA2000
For 28014 1 SetCacheMode {base} 0x10000 Valid CacheInhibit IOSpace
For 28014 1 SetCacheMode {base+0x10000} {size-0x10000} Valid CacheInhibit NonSerial Imprecise
;Cybervision Z3
For 8512 34 Z3 SetCacheMode {base} {size} Blank IOSpace
For 8512 34 Z3 SetCacheMode {base} 0x01400000 Valid IOSpace CacheInhibit
For 8512 34 Z3 SetCacheMode {base+0x01400000} 0x00c00000 Valid IOSpace CacheInhibit NonSerial Imprecise
For 8512 34 Z3 SetCacheMode {base+0x02000000} 0x02000000 Valid IOSpace CacheInhibit
;CyberVision 3D
For 8512 67 SetCacheMode {base} {size} Blank IOSpace
For 8512 67 Z2 SetCacheMode {base} 0x00380000 Valid IOSpace CacheInhibit NonSerial Imprecise
For 8512 67 Z2 SetCacheMode {base+0x00380000} 0x00080000 Valid IOSpace CacheInhibit
For 8512 67 Z3 SetCacheMode {base+0x04000000} 0x01000000 Valid IOSpace CacheInhibit NonSerial Imprecise
For 8512 67 Z3 SetCacheMode {base+0x05000000} 0x00010000 Valid IOSpace CacheInhibit
For 8512 67 Z3 SetCacheMode {base+0x05800000} 0x00008000 Valid IOSpace CacheInhibit
For 8512 67 Z3 SetCacheMode {base+0x07000000} 0x00008000 Valid IOSpace CacheInhibit
For 8512 67 Z3 SetCacheMode {base+0x08000000} 0x00001000 Valid IOSpace CacheInhibit
For 8512 67 Z3 SetCacheMode {base+0x0c000000} 0x00010000 Valid IOSpace CacheInhibit
For 8512 67 Z3 SetCacheMode {base+0x0c0e0000} 0x00001000 Valid IOSpace CacheInhibit
;Rainbow III
For 2145 33 SetCacheMode {base} {size} Blank IOSpace
For 2145 33 SetCacheMode {base} 0x00400000 Valid IOSpace CacheInhibit
;MK-III SCSI Hostadapter
For 8512 100 SetCacheMode {base} {size} Valid IOSpace CacheInhibit
;Blizzard PPC SCSI Hostadapter
For 8512 110 SetCacheMode {base} {size} Valid IOSpace CacheInhibit
; The following define areas for the CBM bridgeboards. These boards
; actually do not need the caching mode setup indicated below, but
; the buggy 32.xx and 33.xx janus.library and tools will.
; Therefore, remove the comments below if you *must* run these buggy
; versions.
;A2088 Bridgeboard
;For 513 1 SetCacheMode 0x00e00000 0x00180000 Valid IoSpace CacheInhibit
;A2286 Bridgeboard
;For 513 2 SetCacheMode 0x00e00000 0x00180000 Valid IoSpace CacheInhibit
;A2386 Bridgeboard
;For 513 103 SetCacheMode 0x00e00000 0x00180000 Valid IoSpace CacheInhibit
; now execute the P5Init command in LIBS:mmu to run the P5 wierdos
P5Init
; that's all folks!
Thanks for the reply my_pc_is_amiga!
1.Workbench:Libs> list 68#?.library
68020.library 2424 ----rwed 13-Apr-21 02:45:24
68030.library 2532 ----rwed 13-Apr-21 02:45:24
68040.library 43924 ----rwed 13-Apr-21 02:45:24
68060.library 65476 ----rwed 17-Aug-22 19:01:26
680x0.library 864 ----rwed 13-Apr-21 02:45:24
5 files - 112K bytes - 231 blocks used
1.Workbench:Libs> version 680x0.library full
680x0.library 46.1 (07/04/16)
(c) 1999-2016 The MMU.lib development group, THOR
1.Workbench:Libs> version 68020.library full
68020.library 46.4 (07/23/17)
1.Workbench:Libs> version 68030.library full
68030.library 46.6 (02/18/21)
1.Workbench:Libs> version 68040.library full
68040.library 46.3 (04/30/17)
1.Workbench:Libs> version 68060.library full
68060.library 47.2 (07/06/22)
(c) 1999-2022 The MMU.lib development group, THOR
I looked at my MMU config, and I've commented out all the video cards since it's an A1200... Same with the Z2cache. I did have the "DescriptorCacheInhibit ON" enabled, so I disabled it and had the same result at boot.
I see P5Init in libs:mmu/
> version p5init
P5Init 46.4
> version p5init
P5Init 46.4
