More compiler issues
OldFart
Post by OldFart »
Whilst continuing playing with various compilers, I encounter other and quite unexpected issues.
As I learned in my previous thread, gcc 6.4.0 requires an upgraded version of newlib.library, so that issue can be dealt with.
gcc 8.4.0 is currently the only version that does its trick, as gcc 10.3.0 now states something about multiple definitions. Other versions do not mention this issue, so I gather in all my wisdom, that this might be a compiler issue?
gcc 11.2.0 now has a problem with inclusion of stddef.h (what the heck is #include_next about?).
Anyone any idea about what to do with the issues of gcc 10.3.0 and gcc 11.2.0?
OldFart
gcc-6 -DCOMPVERS="GCC_6.4.0" -DPROGNAME="AssignView" -DPROGREVN="6" -DPROGVERS="2" -DSDKVERS="54.16" -DUSE_WBRUN -DUSE_SINGLERUNNING  main.c -o ProjecT.DEBUG -Wall -Wextra -Winline -Wunreachable-code -Wstack-protector -Wno-fallthrough -DDEBUG -DGCC -gstabs
SDK:gcc/ppc-amigaos/bin/libexec/gcc/ppc-amigaos/6.4.0/cc1 requires newlib.library 53.68 or newer!
SDK:gcc/ppc-amigaos/bin/libexec/gcc/ppc-amigaos/6.4.0/cc1 faalt returncode 20
make: *** [ProjecT.DEBUG] Error 1
gcc-8 -DCOMPVERS="GCC_8.4.0" -DPROGNAME="AssignView" -DPROGREVN="6" -DPROGVERS="2" -DSDKVERS="54.16" -DUSE_WBRUN -DUSE_SINGLERUNNING  main.c -o ProjecT.DEBUG -Wall -Wextra -Winline -Wunreachable-code -Wstack-protector -Wimplicit-fallthrough=0  -DDEBUG -DGCC -gstabs
=== Done making DEBUG ==========================
gcc-10 -DCOMPVERS="GCC_10.3.0" -DPROGNAME="AssignView" -DPROGREVN="6" -DPROGVERS="2" -DSDKVERS="54.16" -DUSE_WBRUN -DUSE_SINGLERUNNING  main.c -o ProjecT.DEBUG -Wall -Wextra -Winline -Wunreachable-code -Wstack-protector -Wimplicit-fallthrough=0  -DDEBUG -DGCC -gstabs
/tmp/ccF9SaO2.o: In function `Fill_DeadBeef':
CommonFunctions.c:156: multiple definition of `SysBase'
/SDK/newlib/lib/crtbegin.o:(.sbss+0x10): first defined here
CommonFunctions.c:156: multiple definition of `IExec'
/SDK/newlib/lib/crtbegin.o:(.sbss+0x8): first defined here
CommonFunctions.c:156: multiple definition of `DOSBase'
/SDK/newlib/lib/crtbegin.o:(.sbss+0xc): first defined here
CommonFunctions.c:156: multiple definition of `IDOS'
/SDK/newlib/lib/crtbegin.o:(.sbss+0x4): first defined here
gcc-11 -DCOMPVERS="GCC_11.2.0" -DPROGNAME="AssignView" -DPROGREVN="6" -DPROGVERS="2" -DSDKVERS="54.16" -DUSE_WBRUN -DUSE_SINGLERUNNING  main.c -o ProjecT.DEBUG -Wall -Wextra -Winline -Wunreachable-code -Wstack-protector -Wimplicit-fallthrough=0  -DDEBUG -DGCC -gstabs
In file included from /SDK/newlib/include/sys/_types.h:24,
                 from /SDK/newlib/include/sys/reent.h:14,
                 from /SDK/newlib/include/string.h:11,
                 from main.c:31:
/SDK/newlib/include/stddef.h:2:15: fatal error: stddef.h: No such file or directory
    2 | #include_next <stddef.h>
compilation terminated.
X5000, stored.
Dead MicroA1
RaspBerry Pi 2B, 3B, 4B/4Gb, 4B/8Gb, 5B
OrangePi 5+ 8Gb
ACER Aspire Windows 10
polluks
Re: More compiler issues
Post by polluks »
#include_next has some advantages,
see https://stackoverflow.com/questions/102 ... -a-project
Try SnoopDos to fix your issue.
OldFart
Post by OldFart »
Hi all,
                 from main.c:31:
This one issue is simple to mitigate as I have found by experience, by just trying again...
OldFart
X5000, stored.
Dead MicroA1
OrangePi 5+ 8Gb
walkero
Site Admin
Post by walkero »
@oldfart
About the gcc 10 and the multiple definitions you mentioned above, this is not a compiler bug but a change of the new versions.
You can find more info at https://wiki.gentoo.org/wiki/Project:To ... fno_common
You can still have it working by setting the behaviour as it was on compilation
If you develop or want to develop for AmigaOS 4.x, then join us at OS4Coding.net
salass00
Post by salass00 »
@OldFart
If you don't need vbcc support you could try deleting the file "SDK:newlib/include/stddef.h" to see if it helps, or produces a different error.
