IPrefsObjects
alfkil
IPrefsObjects
Post by alfkil »
I have created this class :
#include <proto/application.h>
#include <string>
#include <iostream>
using namespace std;
class Config {
private:
    struct Library *ApplicationBase = NULL;
    struct ApplicationIFace *IApplication = NULL;
    struct PrefsObjectsIFace *IPrefsObjects = NULL;
private:
    PrefsObject *dict;
    string file;
public:
    Config(string file);
    ~Config();
    int getValue(string object, string value, int def);
    void setValue(string object, string value, int number);
#include <proto/exec.h>
#include "Config.hpp"
Config::Config(string file) {
    ApplicationBase = IExec->OpenLibrary("application.library", 52);
    if(ApplicationBase)
        IPrefsObjects = (struct PrefsObjectsIFace *) IExec->GetInterface(ApplicationBase, "prefsobjects", 2, NULL);
    this->file = file;
	uint32 error;
	dict = IPrefsObjects->PrefsDictionary(NULL, &error, ALPO_Alloc, 0, TAG_DONE);
	if(error) {
        cout << "Error creating prefs object " << file << "\n";
        return;
	error = IPrefsObjects->ReadPrefs(dict, READPREFS_FileName, file.c_str(), TAG_DONE);
	if(error) {
        cout << "Error opening prefs file " << file << "\n";
Config::~Config() {
	uint32 error = IPrefsObjects->WritePrefs(dict, WRITEPREFS_FileName, file.c_str(), TAG_DONE);
	if(error) {
        cout << "Error writing to prefs file " << file << "\n";
	IPrefsObjects->PrefsDictionary(dict, &error, ALPO_Release, 0, TAG_DONE);
    IExec->DropInterface((struct Interface *)IPrefsObjects);
    IExec->CloseLibrary(ApplicationBase);
int Config::getValue(string object, string value, int def) {
    PrefsObject *o = IPrefsObjects->DictGetObjectForKey(dict, object.c_str());
    return IPrefsObjects->DictGetIntegerForKey(o, value.c_str(), def);
void Config::setValue(string object, string value, int number) {
    uint32 error;
    if(!o) {
        o = IPrefsObjects->PrefsDictionary(0, &error, ALPO_Alloc, 0, TAG_DONE);
        IPrefsObjects->DictSetObjectForKey(dict, o, object.c_str());
	IPrefsObjects->DictSetObjectForKey(o,
        IPrefsObjects->PrefsNumber(NULL, &error, ALPONUM_AllocSetLong, number, TAG_DONE),
        value.c_str());
It works, but I get strange gui locks on my windows when using it. If I remove reference to it, the gui lock ups go away.
What is wrong?
alfkil
Re: IPrefsObjects
Post by alfkil »
It was apparently due to a faulty USB mass storage device. Problem solved.
