SDK 54.16 newlib math.h problem
blmara
Post by blmara »
I've got a project that includes newlib math.h in one module. This is compiled with VBCC 0.9h. After installing SDK 54.16, including the SDK version of VBCC, I get this error when compiling the project
'vbcc:bin/vc +newlib -cpp-comments -Lvlibos4: -ISDK:local/newlib/include/ -ISDK:local/common/include/ -g -static  -c -o o/lineclass.o lineclass.c
>          ((sizeof(x)==sizeof(float)) ? __fpclassifyf(x) : __fpclassifyd(x))
error 272 in line 282 of "math.h": macro 'fpclassify' redefined unidentically
    included from file "lineclass.c":30
1 error found!
vbccppc keskeytyi, palautuskoodi 20
vbccppc -quiet "lineclass.c" -o= "T:t_9_0.asm" -cpp-comments -ISDK:local/newlib/include/ -ISDK:local/common/include/ -g -elf -no-regnames -no-multiple-ccs -madd -setccs -use-commons -D__amigaos4__ -D__NEWLIB__ -D__mask=___mask  -O=1 -ISDK:local/common/include -ISDK:local/newlib/include -ISDK:newlib/include -ISDK:include/include_h failed
vbcc:bin/vc keskeytyi, palautuskoodi 20
Asked about this from Frank Wille, the author of Amiga version of VBCC. His answer
I didn't check the new SDK yet, but it looks like a problem in the newlib
math.h from SDK 54.16, which is not part of vbcc.
__fpclassifyd(x))
unidentically
My SDK has just:
extern int __fpclassifyf (float x);
extern int __fpclassifyd (double x);
Probably the new SDK has a second declaration for __fpclassifyX() somewhere?
Then this is a bug, which should be reported.
How and who to correct this problem?
Marko
Marko
salass00
Re: SDK 54.16 newlib math.h problem
Post by salass00 »
Since it complains that fpclassify is being redefined unidentically can you find where the other definition is (is it in the program you are compiling, a vbcc internal header or ...)? When using gcc and it encounters a problem like this it lists also the previous definition which is a quite handy feature.
salass00
Post by salass00 »
Okay, I found the problem: The fpclassify macro is first defined in a compiler generic section nearer the top of the header file and then defined again lower down in a VBCC specific section.
This modified math.h header file should fix the double macro definitions when using VBCC:
https://www.dropbox.com/s/oh1rf9quvgel7aa/math.h?dl=0
blmara
Post by blmara »
Thanks and sorry for delay replying,
the DropBox link provided in the previous message doesn't seem to work with Amiga Browsers (Odyssey, Netsurf) but with the help of my Android phone I manage to download the new math.h. Now it compiles flawlessly with VBCC. Thanks a lot! Hopefully this will go to the next update of SDK.
Marko
Marko
The link works if you change the last 0 to 1.
dl=1 means the site won't load, instead it will immediately download the file
