Hyperion U-boot version, DMA - fix
sailorMH
Post by sailorMH »
I got from colleague AmigaOne XE. And I have some questions.
1. What is correct U-Boot version from Hyperion?
On Hyperion download site is written "AmigaOne Firmware Update *05-Mar-2005*"
And version which is on my AmigaOne is: U-Boot 1.1.1 (Mar 3 2005 - 16:42:53)
This is two days difference. Is it hotfix or some mistake?
Please do somebody have AmigaOne with last Hyperion U-Boot and can check the version from computer?
Can I flash it?
I also have Micro with U-Boot 1.2.0 and it is working perfectly. Is there way howto download U-Boot without removing the ROM? Then I can flash XE with newer experimental U-Boot.
2. My board is DMA fix.
There viewtopic.php?f=16&t=1889 is perfect explanation from tonyw what DMA fix is.
Is possible to do Un-Fix ?
Have somebody exact information which tracks were cutted?
I want to made some experiments and need to use PCI 66MHz slot.
Or, if somebody have unfixed AmigaOne ;-)
Re: Hyperion U-boot version, DMA - fix
@sailorMH
1 - iirc the two day difference comes simply from the fact that uboot was compiled on the 3rd of march, but officially released two days later.
2. Everything is possible, the question is
a) will you find someone who has the blueprints of the fix, the means and skill and is willing to un-fix
and
b) are *you* willing to probably brick a perfectly fine board?
Good luck
ZeroG
Post by ZeroG »
You can find the blueprints for the DMA (and USB) fix here.
sailorMH
Post by sailorMH »
@raziel
thanks, number6 also confirm this. It is good news, I cannot reflash it.
and no, I don't want to brick it. I want to improve it ;-). I know, it is the risk, but upto now I didn't destroy any of my old computers.
sailorMH
Post by sailorMH »
@ZeroG
Many thanks!
Please is possible to send it to me via PM, attachment or similar? Because on www.os4welt.de the attached files are hidden, if I am not logged on.
And is something curious to make here registration for single file...
sailorMH
Post by sailorMH »
Thanks to all, I got the files!
Tijatjj
Post by Tijatjj »
Hi it’s a little late however were you able to get the A1 xe rom file flashed as I also need this to get fixed thanks
