Fienix 5.1 Spark
Fienix 5.1 Spark
Great news! :-)
caseycullen wrote: Wed Apr 06, 2022 7:48 am I've uploaded an image for Fienix 5.1, codename Spark. It was a considerable task to weed out and fix packages this time, due to what I believe was an unfortunate and misguided decision at Debian. That said, most packages in Fienix Spark are the current version. However, I've held back KDE/Qt packages a few versions to ensure their operability and stability. I plan on building KDE/Qt packages myself for future updates instead of importing them from Debian since they seem to be the most problematic.
Spark is basically a stability release with quite a few refinements and creates a good foundation for going forward. Hopefully you can try it out!
Fienix Download Page Choose "Download Fienix Live Image" (second button).
Notes:
Spark starts in "compatibility mode" with fbdev and effects turned off. If you have a supported GPU you can use Fienix Companion to enable hardware acceleration.
If you require an input method platform, as I believe kilaueabart uses, please try SCIM.
Thanks!
Casey
Re: Fienix 5.1 Spark
Hi
Have install Spark and its look nice , but i got a can't connect to server when trying to update or install.
musa wrote: Thu Jun 02, 2022 9:06 pm Hi
Hi Musa,
I asked Casey because of this issue today.
He has answered the following:
Casey wrote: Repo server is still down because I had to move, I’ll have it up tomorrow
Casey wrote: UPDATE: Fienix Repository Down Until 6/6/2022
UPDATE: The Fienix Repositories are down until June 6, 2022. Users will not be able to install software using apt or synaptic during this time. Apologies for any inconvenience.
xeno74 wrote: Sun Jun 05, 2022 2:03 pm
Thanks for info
have a nice day
HI
I have updated Fienix and installed the programs I usually use. Everything went well.
In addition, I have installed Danish language files and it also works well.
Installed locale in synaptic and then used the information from this web page.
Fienix works really well here. https://wiki.debian.org/ChangeLanguage
Have a nice day
Primax wrote: Sat Oct 22, 2022 6:38 am Finally, the first part of my article about using Fienix on an AmigaOne X5000 has been published:
https://www.amiga-news.de/de/news/AN-20 ... 91-DE.html
Hope, you like it....:)
Daniel
It is really great! Thank you! :-)
Link to the English version: Linux tutorial: Using the Fienix distribution on the X5000, part 1 -- amiga-news.de
