New USB Keyboard not recongnized by Uboot
gordini21
Post by gordini21 »
Hello,
I ahve an issue with my new USB Keyboard. It is not recognized by Uboot. So when i want to switch between Morphos or Fienix i need to plug my old apple keyboard to enter the menu.
It works fine with Morphos or Fienix.
I have tried to plug the keyboard during the boot, the same it is not recognized.
Any idea ?
thanks
Re: New USB Keyboard not recongnized by Uboot
Are you using a KVM switch by any chance?
If yes, try having it switched to another port when you turn on or reboot the X5k, waiting 20-22 seconds and then switching to the port with the X5k, at least that's what I have to do to have a working keyboard in UBoot/AmigaBoot.
gordini21
Post by gordini21 »
not using this switch i am directly connected to the USB on the motherboard
gordini21 wrote: Thu Mar 10, 2022 5:29 pm not using this switch i am directly connected to the USB on the motherboard
Does your X5000 boot directly to an OS? If yes, please reboot your X5000 and try it again.
My keyboard always doesn't work after the first boot but it works after a reboot.
gordini21
Post by gordini21 »
Yes the X5000 boots directly to morphos and it works very well
but it is impossible to enter the uboot menu even after a reboot
when i need to switch to fienix i have to plug my old keyboard i don't understand why
it is very strange it is a standrad usb keyboard, the only différence beetween my old keyboard is that you can use the keyboard with a wireless link but i use ut with a physical link so ....
