So at first I got no boot sceen...nothing, rechecked every connection, nothing.
saw three led lights, so thought, might of move or hit the CMOS battery, (even though I did'nt remove it for the clean) anywho, nothing, then replace the CMOS battery, now I get a boot screen
But then it takes me to command line, and complains about lack of memory, "Failed to load amigaboot.of: Insufficient memory"
so played about with SATA connections, if I put HDD to SATA2 and CD Drive to SATA1, I get a little futher, up to the OS boot menu, but on slection, I then get a bunch of error message say this or that is missing to the point it just locks up. then second boot up, Im back to "Failed to load amigaboot.of: Insufficient memory".
Tried the remove RAM on one side trick, do you think I need a new SATA cable and HARDIVE? I was thinking about getting a SSD for the machine, start with a fresh install, do you think that would fix it?
Why does a simple clean where I bearly touch the dam things can brick the system, never had a computer where moving a SATA cable seem so sentive, and so many of the Troubleshooting tips seem to be about SATA. did Varisys cheap out?
Thanks if anyone can help. I tell you I getting closer and closer to selling my X1000, seems every couple of months of fairly light use I get another new problem, I dont have much free time, and starting to find my fixs on Pi + Amikit XE for quick Amiga time.
