Fienix ssd
Tijatjj
Fienix ssd
Post by Tijatjj »
Hi copied fienix from usb but says only 5gig,4.7gib. The image says 6.3gig this is the 608 version .is something amiss here. Fat load 1st line reports back but the next 2 do not .the Cyrus p5020 and the uInitrd not there ? Did it for some reason not dd the whole image.Just used gpt not msdos.Then just copied over thanks this is placing on a ssd. It starts to load and then stops
Tijatjj
Re: Fienix ssd
Post by Tijatjj »
Tijatjj wrote: Sat Nov 20, 2021 12:38 am Hi copied fienix from usb but says only 5gig,4.7gib. The image says 6.3gig this is the 608 version .is something amiss here. Fat load 1st line reports back but the next 2 do not .the Cyrus p5020 and the uInitrd not there ? Did it for some reason not dd the whole image.Just used gpt not msdos.Then just copied over thanks this is placing on a ssd. It starts to load and then stops
Tijatjj
Re: Fienix ssd
Post by Tijatjj »
So it says /sbin/init .exec format error.kernel panic not syncing.file system check failed but did not detect any errors.mounted file system with ordered data mode.then Fsck has exited with status code 8 .sorry have a picture but says board has reached limit even though it’s under the 5meg thanks
Re: Fienix ssd
Did you copy the whole USB stick to an empty hard disk?
Tijatjj
Re: Fienix ssd
Post by Tijatjj »
Thanks, not sure though it unpacked to 6.3 but says only 5gig ,4.7Mib. So I don’t know for sure.Should I have it just reinstalled thanks ( meaning 5 gig,4.7 dd to sda)
Re: Fienix ssd
Tijatjj wrote: Sat Nov 20, 2021 5:57 pm Thanks, not sure though it unpacked to 6.3 but says only 5gig ,4.7Mib. So I don’t know for sure.Should I have it just reinstalled thanks ( meaning 5 gig,4.7 dd to sda)
I am sorry I don’t understand what you mean. Can you boot from the Fienix USB stick?
Tijatjj
Re: Fienix ssd
Post by Tijatjj »
Hi thank you for the relpy. It’s copied over from aolt usb stick.problem seems to be resize. It says sda 1 and sda2. Sda2 says fienix-soar. But it’s only 5gig partition that is copied over.the ssd is a 1 terabyte drive.there are no other partitions on the drive .can use the whole ssd type drive makes no difference.But how to get this done thanks again.
Re: Fienix ssd
Tijatjj wrote: Mon Nov 22, 2021 5:04 am Hi thank you for the relpy. It’s copied over from aolt usb stick.problem seems to be resize. It says sda 1 and sda2. Sda2 says fienix-soar. But it’s only 5gig partition that is copied over.the ssd is a 1 terabyte drive.there are no other partitions on the drive .can use the whole ssd type drive makes no difference.But how to get this done thanks again.
You can use GParted from the booted AOTL Fienix USB stick for enlarging the partition and resizing the root file system (fienix-soar).
Tijatjj
Re: Fienix ssd
Post by Tijatjj »
Hi anyone know what this error means . Hi getting errors trying to boot to hd.did not use root delay as per instructions.
Says check root delay,check root,did it wait long enough or the right device.another is missing modules. And then ALERT LABEL=FIENIX-DISK does not exist ,dropping to a shell? Totally clueless thanks for help in advance.Happy Holidays to all
Re: Fienix ssd
Tijatjj wrote: Thu Nov 25, 2021 12:27 am Hi anyone know what this error means . Hi getting errors trying to boot to hd.did not use root delay as per instructions.
Did you boot with an initial ramdisk (uInitrd)? You need to boot with an initial ramdisk if you want to use a label.
