AmigaOS 4.1FE, blizzardPPC and red/blue screen
reflex79
Post by reflex79 »
Hello,
i'm installing AmigaOS 4.1FE on my BlizzardPPC with mediator and Voodoo 3 but everytime I start the installation process, after getting the screen that tells me that the system will switch on the VGA/RTG board the screen becomes red then blue then red again and everything stops, disk ecc... stuck on the red screen.
I cannot test the PPC in any other way but could it be a faulty PPC chip problem?
The blizzard still has the original cooling fan (that makes a lot of noise).
Did anyone experience the same issue? How can i solve?
polluks
Re: AmigaOS 4.1FE, blizzardPPC and red/blue screen
Post by polluks »
Hmm, did you check with Sonnet?
https://github.com/Sakura-IT/SonnetAmiga
