Fienix
Tijatjj
Fienix
Post by Tijatjj »
Hi , I was wondering if you can just copy the usb fienix from the AOTL stick to a hd while u are using it. There is not enough room in the usb to download again and place it in hd. Thanks
Re: Fienix
Tijatjj wrote: Thu Sep 16, 2021 6:31 pm Hi , I was wondering if you can just copy the usb fienix from the AOTL stick to a hd while u are using it. There is not enough room in the usb to download again and place it in hd. Thanks
Hi Tijatjj,
Good hint! It would be good if we have bigger AOTL sticks including the Fienix img in its file system.
@Casey
What do you think?
Tijatjj
Re: Fienix
Post by Tijatjj »
Yes , they say the third time is a charm,first one got bent out of shape.
