Installing/using python scripts
Can python scripts from github be used with our Linux distros? How about this one: https://github.com/itorres/super3acasa? How shoud it be installed and started? I am not at all familiar with python...
caseycullen
Re: Installing/using python scripts
Post by caseycullen »
Roland wrote: Wed Sep 08, 2021 10:26 pm Can python scripts from github be used with our Linux distros? How about this one: https://github.com/itorres/super3acasa? How shoud it be installed and started? I am not at all familiar with python...
Generally you start python apps with "python3 appname.py" (or python appname.py for python 2); so in this case you'd cd to the directory containing tv3dl.py and then enter "python3 tv3dl.py". Many python apps require additional python libraries to run, in this case the app requires beautifulsoup4==4.4.1, lxml==3.6.0, PyYAML>=4.2b1 and requests>=2.20.0 (according to their "requirements" page on GitHub).
In Fienix, beautifulsoup4 is provided by the package "python3-bs4", lxml is provided by "python3-lxml", PyYAML is provided by python3-ruamel.yaml (I think) or python3-saneyaml, and requests is provided by python3-requests. You just need to make sure you have those packages installed in order to run the tv3dl.py app.
Python apps are highly compatible as long as we have all of the required libraries available.
-Casey
caseycullen wrote: Thu Sep 09, 2021 7:41 pm Generally you start python apps with "python3 appname.py" (or python appname.py for python 2); so in this case you'd cd to the directory containing tv3dl.py and then enter "python3 tv3dl.py". Many python apps require additional python libraries to run, in this case the app requires beautifulsoup4==4.4.1, lxml==3.6.0, PyYAML>=4.2b1 and requests>=2.20.0 (according to their "requirements" page on GitHub).
Thank you very much for your advice!
But I was not able to find 'python3-ruamel.yaml' or 'python3-saneyaml' from the Fienix depot... Should they be there?
caseycullen
Roland wrote: Thu Sep 09, 2021 10:40 pm Thank you very much for your advice!
I thought so; I'll check and add if they're not.
caseycullen wrote: Fri Sep 10, 2021 3:15 pm
Roland wrote: Thu Sep 09, 2021 10:40 pm But I was not able to find 'python3-ruamel.yaml' or 'python3-saneyaml' from the Fienix depot... Should they be there?
I was able to install PyYAML with pip3... But when I try to run the script as you adviced, I get this:
> python3 tv3dl.py
Traceback (most recent call last):
File "tv3dl.py", line 9, in <module>
import yaml
ModuleNotFoundError: No module named 'yaml'
caseycullen
Roland wrote: Fri Sep 10, 2021 8:04 pm
> python3 tv3dl.py
import yaml
Try installing python3-yaml from the Fienix repository.
caseycullen wrote: Mon Sep 13, 2021 8:20 pm Try installing python3-yaml from the Fienix repository.
Thanks! After installing that component the script started to work. But is does not seem to find anything to download, it just goes through a long list of dirs:
Starting
tv3dl.py:52: YAMLLoadWarning: calling yaml.load() without Loader=... is deprecated, as the default Loader is unsafe. Please read https://msg.pyyaml.org/load for full details.
  self._config = yaml.load(f)
Getting chapters for 10+2
No tag with title "Vídeos" found
Getting chapters for Artús i els vailets de la Taula Rodona
Getting chapters for Asha
Getting chapters for Avatar, la llegenda de la Korra
Getting chapters for Avui aprenem
Getting chapters for Bestial!
Getting chapters for Bola & Bill
I wonder if the config file (Yaml.config) is out of date, or configured too specifically:
dirs:
  base: /nas/4TB2/Media/In/tv3
  download: /nas/4TB2/Media/In/tv3/d
  index: /nas/4TB2/Media/In/tv3/index
  publish: /nas/4TB2/Media/Video/Infantil
:publish:
  "Doraemon, el gat còsmic":
  "Doraemon": "Doraemon, el gat còsmic"
  "Monster allergy":
  "Monster Allergy": "Monster allergy"
  "Una mà de contes":
  "Ua man de condes": "Una mà de contes"
  "Els Dalton":
  "El llibre de la selva":
  "Bob, el manetes":
  "Bob el manetes": "Bob, el manetes"
  "Bob, el manetes: a peu d'obra": "Bob, el manetes"
  "Bob, el manetes: el Llampec al rescat": "Bob, el manetes"
  "Marsupilami":
  "Rekkit, el conill màgic":
  "Rekkit rabbit": "Rekkit, el conill màgic"
  "L'hora del Timmy":
  "Geronimo Stilton":
  "La vaca Connie":
  "MIC":
  "Mic": "MIC"
  "Xilòfon i Mic en capsa": "MIC"
  "Les noves aventures de Peter Pan":
  "Zoobabu":
  "Els caçadors d'elements":
  "Els germans Kratt":
  "Invizimals":
  "LazyTown - Vilamandra":
  "El xai Shaun":
  "Rovelló":
  "El carnaval de la Ventafocs (Rovelló)": "Rovelló"
  "Teo":
  "Monstres supersans":
  "La vaca Connie":
  "Les misterioses ciutats d'or":
  "La casa d'Anubis":
  "La Casa d'Anubis": "La casa d'Anubis"
How should it be modified to 'find' this video:
https://www.ccma.cat/tv3/alacarta/transmissions-esportives/holanda/video/6117256/
There is also an ordinary script included with the python ones:
#!/usr/bin/env bash
IMAGE_NAME=itorres/tv3dl
COMMAND=/usr/src/app/tv3dl.py
VOLUME=$(awk -F ': ' '/base:/ {print $2}' config.yaml)
function exec_build {
    docker build -t itorres/tv3dl .
function exec_run {
    docker run --rm -ti -v $VOLUME:$VOLUME -v $(pwd):/usr/src/app ${IMAGE_NAME} $COMMAND
while getopts ":bc" opt; do
    case $opt in
        c)
            exec_build
	b)
	    COMMAND=bash
    esac
done
docker images | grep -q ${IMAGE_NAME} || exec_build
exec_run
If I try to run it in terminal, I get this kind of error messages:
Fienix:~/Scripts/super3acasa-master$ '/home/roland/Scripts/super3acasa-master/run.sh'
/home/roland/Scripts/super3acasa-master/run.sh: line 22: docker: command not found
/home/roland/Scripts/super3acasa-master/run.sh: line 6: docker: command not found
/home/roland/Scripts/super3acasa-master/run.sh: line 9: docker: command not found
What is that 'docker' command which seems to be missing?
caseycullen
Roland wrote: Mon Sep 27, 2021 10:40 am
Starting
dirs:
:publish:
  "Monster allergy":
  "Una mà de contes":
  "Els Dalton":
  "Bob, el manetes":
  "Marsupilami":
  "L'hora del Timmy":
  "Geronimo Stilton":
  "La vaca Connie":
  "MIC":
  "Mic": "MIC"
  "Zoobabu":
  "Invizimals":
  "El xai Shaun":
  "Rovelló":
  "Teo":
  "La vaca Connie":
  "La casa d'Anubis":
#!/usr/bin/env bash
function exec_run {
    case $opt in
        c)
            exec_build
	b)
	    COMMAND=bash
    esac
done
exec_run
I took a closer look at the tv3dl source code, and it looks like ccma.cat has made changes that broke the app. For example, I found several hard-coded URLs that aren't valid addresses anymore, like "https://www.ccma.cat/tv3/alacarta/programes/" and "http://dinamics.ccma.cat/pvideo/media.jsp".
Docker is a type of container, kind of like snap. The script that you referenced packages the application in a Docker container, which isn't helpful for the problem we're running into.
Hmm... have you tried asking sebaro if ViewTube+ may be able to support ccma.cat videos? If not, you could try asking at sebaro.pro/contact/. This would make the videos playable in Interweb or Arctic Fox.
Otherwise, you may be able to use youtube-dl with a command like "youtube-dl -f 480p -o - https://www.ccma.cat/tv3/alacarta/trans ... o/6117256/ | vlc". I'm not sure if it will work, but youtube-dl works for several video/streaming sites.
caseycullen wrote: Mon Sep 27, 2021 8:27 pm I took a closer look at the tv3dl source code, and it looks like ccma.cat has made changes that broke the app. For example, I found several hard-coded URLs that aren't valid addresses anymore, like "https://www.ccma.cat/tv3/alacarta/programes/" and "http://dinamics.ccma.cat/pvideo/media.jsp".
Ok, thanks for checking it... We can forget that script.
I have ViewTube+ already installed and it does not support ccma.cat. Sebaro added earlier one other site to ViewTube+ on my demand... I'm not sure if I dare to ask him to add another one !-)
To my surprice, youtube-dl indeed works with ccma.cat. It did not come to my mind to test it as I thought it works only with Youtube.
Problem solved... Thank you very much for your help !-)
BTW. I noticed yesterday that the "Video DownloadHelper" plugin can be installed manually on the PaleMoon family of browsers! It did not succeed to download videos from ccma.cat but it worked with some other sites. In your future versions of Fienix, it might not be a bad idea to preinstall it on the browsers...
caseycullen
Roland wrote: Mon Sep 27, 2021 9:07 pm To my surprice, youtube-dl indeed works ccma.cat. It did not come to my mine to test it as I thought it works only with Youtube.
Nice, I'm glad we found a solution that works for you! I use youtube-dl for Twitch, too. It's more versatile than the name would lead one to believe!
Roland wrote: Mon Sep 27, 2021 9:07 pm BTW. I noticed yesterday that the "Video DownloadHelper" plugin can be installed manually on the PaleMoon family of browsers! It did not succeed to download videos from ccma.cat but it worked with some other sites. In your future versions of Fienix, it might not be bad idea to preinstall it on the browsers...
Thanks for the suggestion; I'll check it out.
-Casey
