Supplemental line feed(0x0A) and end of file(EOF) not logical
gdridi
Post by gdridi »
Hello,
When I´m creating a file like (supposed to be an empty file) :
> cat >file.txt
Ctrl-\
And close immediately with Ctrl-\ (0x1C on Amiga)
The file.txt is not empty file but contains a line feed char (0x0A).
This is illogic like the test program joined (and this can lead to hard to find behavior "in programmer life also").
#include <stdio.h>
// Close the input stream just after with Ctrl-\
// and it will NOT print that it is EndOfFile !
// We think this is due to a linefeed(LF) insertion before close of the DOS stream in : con-handler
int main() {
	int c = getchar();
	if ( c == EOF ) printf ("*** End Of File ***\n");
	else printf("char %d\n", c);
DGILLES
Post scriptum : if the bug is in con-handler it can be a rapid fix to upload the separated file I.e. con-handler on a place where everyone can download it(expecting a new update of AmigaOS).
Re: Supplemental line feed(0x0A) and end of file(EOF) not logical
I'm not sure that this is a bug. It seems logical to me that if you create an ASCII (not binary) file with cat or any other ASCII-oriented program, that it ought to contain at the very least an empty line terminated by a NL.
I put it on my list of things to look into, but it's not a high priority. You can always create an empty file with the command:
"echo >emptyfile" -with no text to enter into it. That will create a completely empty file.
gdridi
Post by gdridi »
Hello,
I tried with echo and I sorry to say that’s kind of miss behavior because echo should add a newline except if the NOLiNE option is pass.
Another CMD like the touch Linux one should mimic this echo >empty_file (without text fed).
But for _test strategy_ we have the two differents commands copy and type :
Copy * to ram:toto
Or
Type * to ram:titi
And closing immediately the input stream with Ctrl-\ (0x1C) should give an empty file Toto for copy command and a file which contains newline for titi.
Other methods than copy to create empty file is : echo NOLINE >ram:tutu
Echo is ASCII aware as type, both are Line buffered so newline ; no binary as copy or cat which treated newline like other byte (it seems).
DGILLES - Arabic console os4depot.net
gdridi
Post by gdridi »
Hello!
No one has tested ?
DGILLES
