Void Linux
Void Linux
I tested Void Linux PPC on my X5000 today.
First, I extracted the Void rootfs "void-ppc-ROOTFS-20200411.tar.xz" on a free partition on my X5000. It boots without any problems.
You can log into this system as root with the password "voidlinux".
After that I configured my network with the command "dhcpcd".
If it works then "ln -s /etc/sv/dhcpcd /var/service/dhcpcd".
Then I updated my Void rootfs with the following commands:
After that I rebooted the X5000.
I created a user with the following commands:
  • Code: Select all
    # useradd -m -s /bin/bash -U -G wheel,users,audio,video,cdrom,input amigaone
  • Code: Select all
    # passwd amigaone
To allow the user amigaone system access via the sudo command, you need to edit the file "/etc/sudoers" with "visudo". Uncomment this line: # %wheel ALL=(ALL) ALL.
Afterwards I installed MATE with the following commands:
  • Code: Select all
    sudo xbps-install -S xorg xterm
  • Code: Select all
    sudo xbps-install -S mate
  • Code: Select all
    sudo xbps-install -S mate-utils pluma mate-terminal mate-system-monitor mate-applets alsa-utils pavucontrol glxinfo mesa-demos lightdm lightdm-gtk3-greeter
  • Code: Select all
    sudo ln -s /etc/sv/dbus /var/service/dbus
  • Code: Select all
    sudo ln -s /etc/sv/lightdm /var/service/lightdm
  • Code: Select all
    sudo reboot
Additionally I installed the following packages:
  • Code: Select all
    sudo xbps-install -S hardinfo neofetch vlc wget
With the command "xbps-remove -o <package names>" you can remove packages.
Screenshot of Void Linux on the X5000:
I am looking forward about your experiences with Void. :-)
Re: Void Linux
xeno74 wrote: Thu Aug 19, 2021 3:05 pm
Glad to hear you got it working! Did you already check whether there is for it some interesting software, not available for MintPPC and Fienix?
Ps. When I started the installation following your instructions, the command "# xbps-install -u xbps" gave an error message "The package 'xbps' is not present in repository pool".
Edit: The commands
and
# xbps-install -Suv
has to be run in the opposite oder!
Next problem is, how to change 'nano' to the default editor of 'Visudo'? The original one (vi?) is totally useless, I cannot operate it at all (and the manual is as incomprehensible as the program itself). I already downloaded nano with xbps.
Re: Void Linux
Hi Rolland,
I uploaded a ROOTFS with MATE, VLC, SuperTuxKart, LibreOffice, Gimp, some web browsers with ViewTube etc today.
Download: void-ppc-ROOTFS-20210820.tar.gz
You can log into this system as amigaone with the password "amigaone".
Sorry if I can't answer all questions. I am also new in the Void land.
Re: Void Linux
xeno74 wrote: Fri Aug 20, 2021 5:02 pm I uploaded a ROOTFS with MATE, VLC, SuperTuxKart, LibreOffice, Gimp, some web browsers with ViewTube etc today.
It works on my X1000. :-)
Re: Void Linux
xeno74 wrote: Fri Aug 20, 2021 5:02 pm Sorry if I can't answer all questions. I am also new in the Void land.
I succeeded finally to perform the whole installation cascade. FYI, "EDITOR=nano visudo" was needed to change the default editor to nano. Nothing special, I think...
But I cannot get lightdm to load the dekstop. I have still a Radeon R7 240 in my machine, and I tested the 'xorg.conf' (with 'fbdev' defined) from both Fienix and MintPPC but got only a black screen... Is Void incompatible with fbdev? I do not have here any other graphics board to test.
Re: Void Linux
Roland wrote: Sat Aug 21, 2021 11:48 am Is Void incompatible with fbdev?
I think no. Is the package "xf86-video-fbdev" installed? I didn't need to install it because it was installed automatically.
Re: Void Linux
Date and Time with NTP
Install the package NTP:
sudo xbps-install -S ntp
Enable the service:
sudo ln -s /etc/sv/ntpd /var/service
Reboot and check if the NTP service works:
sudo sv status ntpd
Output: run: ntpd: (pid 2296) 493497782s
Re: Void Linux
Installing the Network-Manager
sudo xpbs-install -S network-manager-applet
Re: Void Linux
I released an img with a boot and root partition including the void-installer today.
Download: void-live-powerpc-20210822.img.tar.gz 3.8G
md5sum: 8bfc1fc6d63c0fc0741c1bd8e3b4078a
Re: Void Linux
xeno74 wrote: Sun Aug 22, 2021 2:59 pm Hi All,
Please add your own favorite kernel and the dtb (X5000) to the small FAT16 partition.
