Z shell
Z shell
Z shell
The Z shell (Zsh) is a Unix shell that can be used as an interactive login shell and as a command interpreter for shell scripting. Zsh is an extended Bourne shell with many improvements, including some features of Bash, ksh, and tcsh.
You can install it with apt install zsh. If you use Fienix then please download the following packages and install them with dpkg -i zsh*.
Downloads: You can configure the Z shell as your default shell with the command chsh -s /usr/bin/zsh <username>.
If you want to use a nice prompt then copy the following .zshrc file to your home directory.
# ~/.zshrc file for zsh interactive shells.
# see /usr/share/doc/zsh/examples/zshrc for examples
setopt autocd              # change directory just by typing its name
#setopt correct            # auto correct mistakes
setopt interactivecomments # allow comments in interactive mode
setopt magicequalsubst     # enable filename expansion for arguments of the form ‘anything=expression’
setopt nonomatch           # hide error message if there is no match for the pattern
setopt notify              # report the status of background jobs immediately
setopt numericglobsort     # sort filenames numerically when it makes sense
setopt promptsubst         # enable command substitution in prompt
WORDCHARS=${WORDCHARS//\/} # Don't consider certain characters part of the word
# hide EOL sign ('%')
PROMPT_EOL_MARK=""
# configure key keybindings
bindkey -e                                        # emacs key bindings
bindkey ' ' magic-space                           # do history expansion on space
bindkey '^[[3;5~' kill-word                       # ctrl + Supr
bindkey '^[[3~' delete-char                       # delete
bindkey '^[[1;5C' forward-word                    # ctrl + ->
bindkey '^[[1;5D' backward-word                   # ctrl + <-
bindkey '^[[5~' beginning-of-buffer-or-history    # page up
bindkey '^[[6~' end-of-buffer-or-history          # page down
bindkey '^[[H' beginning-of-line                  # home
bindkey '^[[F' end-of-line                        # end
bindkey '^[[Z' undo                               # shift + tab undo last action
# enable completion features
autoload -Uz compinit
compinit -d ~/.cache/zcompdump
zstyle ':completion:*:*:*:*:*' menu select
zstyle ':completion:*' auto-description 'specify: %d'
zstyle ':completion:*' completer _expand _complete _correct _approximate
zstyle ':completion:*' format 'Completing %d'
zstyle ':completion:*' group-name ''
zstyle ':completion:*' list-colors ''
zstyle ':completion:*' list-prompt %SAt %p: Hit TAB for more, or the character to insert%s
zstyle ':completion:*' matcher-list 'm:{a-zA-Z}={A-Za-z}'
zstyle ':completion:*' rehash true
zstyle ':completion:*' select-prompt %SScrolling active: current selection at %p%s
zstyle ':completion:*' use-compctl false
zstyle ':completion:*' verbose true
zstyle ':completion:*:kill:*' command 'ps -u $USER -o pid,%cpu,tty,cputime,cmd'
# History configurations
HISTFILE=~/.zsh_history
HISTSIZE=1000
SAVEHIST=2000
setopt hist_expire_dups_first # delete duplicates first when HISTFILE size exceeds HISTSIZE
setopt hist_ignore_dups       # ignore duplicated commands history list
setopt hist_ignore_space      # ignore commands that start with space
setopt hist_verify            # show command with history expansion to user before running it
#setopt share_history         # share command history data
# force zsh to show the complete history
alias history="history 0"
# configure `time` format
TIMEFMT=$'\nreal\t%E\nuser\t%U\nsys\t%S\ncpu\t%P'
# make less more friendly for non-text input files, see lesspipe(1)
#[ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)"
# set variable identifying the chroot you work in (used in the prompt below)
if [ -z "${debian_chroot:-}" ] && [ -r /etc/debian_chroot ]; then
    debian_chroot=$(cat /etc/debian_chroot)
fi
# set a fancy prompt (non-color, unless we know we "want" color)
case "$TERM" in
    xterm-color|*-256color) color_prompt=yes;;
esac
# uncomment for a colored prompt, if the terminal has the capability; turned
# off by default to not distract the user: the focus in a terminal window
# should be on the output of commands, not on the prompt
force_color_prompt=yes
if [ -n "$force_color_prompt" ]; then
    if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then
        # We have color support; assume it's compliant with Ecma-48
        # (ISO/IEC-6429). (Lack of such support is extremely rare, and such
        # a case would tend to support setf rather than setaf.)
        color_prompt=yes
    else
        color_prompt=
    fi
fi
configure_prompt() {
    prompt_symbol=㉿
    [ "$EUID" -eq 0 ] && prompt_symbol=💀
    case "$PROMPT_ALTERNATIVE" in
        twoline)
            PROMPT=$'%F{%(#.blue.green)}┌──${debian_chroot:+($debian_chroot)─}${VIRTUAL_ENV:+($(basename $VIRTUAL_ENV))─}(%B%F{%(#.red.blue)}%n$prompt_symbol%m%b%F{%(#.blue.green)})-[%B%F{reset}%(6~.%-1~/…/%4~.%5~)%b%F{%(#.blue.green)}]\n└─%B%(#.%F{red}#.%F{blue}$)%b%F{reset} '
            RPROMPT=$'%(?.. %? %F{red}%B⨯%b%F{reset})%(1j. %j %F{yellow}%B⚙%b%F{reset}.)'
        oneline)
            PROMPT=$'${debian_chroot:+($debian_chroot)}${VIRTUAL_ENV:+($(basename $VIRTUAL_ENV))}%B%F{%(#.red.blue)}%n@%m%b%F{reset}:%B%F{%(#.blue.green)}%~%b%F{reset}%(#.#.$) '
            RPROMPT=
        backtrack)
            PROMPT=$'${debian_chroot:+($debian_chroot)}${VIRTUAL_ENV:+($(basename $VIRTUAL_ENV))}%B%F{red}%n@%m%b%F{reset}:%B%F{blue}%~%b%F{reset}%(#.#.$) '
            RPROMPT=
    esac
# The following block is surrounded by two delimiters.
# These delimiters must not be modified. Thanks.
# START KALI CONFIG VARIABLES
PROMPT_ALTERNATIVE=twoline
NEWLINE_BEFORE_PROMPT=yes
# STOP KALI CONFIG VARIABLES
if [ "$color_prompt" = yes ]; then
    # override default virtualenv indicator in prompt
    VIRTUAL_ENV_DISABLE_PROMPT=1
    configure_prompt
    # enable syntax-highlighting
    if [ -f /usr/share/zsh-syntax-highlighting/zsh-syntax-highlighting.zsh ] && [ "$color_prompt" = yes ]; then
        . /usr/share/zsh-syntax-highlighting/zsh-syntax-highlighting.zsh
        ZSH_HIGHLIGHT_HIGHLIGHTERS=(main brackets pattern)
        ZSH_HIGHLIGHT_STYLES[default]=none
        ZSH_HIGHLIGHT_STYLES[unknown-token]=fg=red,bold
        ZSH_HIGHLIGHT_STYLES[reserved-word]=fg=cyan,bold
        ZSH_HIGHLIGHT_STYLES[suffix-alias]=fg=green,underline
        ZSH_HIGHLIGHT_STYLES[global-alias]=fg=magenta
        ZSH_HIGHLIGHT_STYLES[precommand]=fg=green,underline
        ZSH_HIGHLIGHT_STYLES[commandseparator]=fg=blue,bold
        ZSH_HIGHLIGHT_STYLES[autodirectory]=fg=green,underline
        ZSH_HIGHLIGHT_STYLES[path]=underline
        ZSH_HIGHLIGHT_STYLES[path_pathseparator]=
        ZSH_HIGHLIGHT_STYLES[path_prefix_pathseparator]=
        ZSH_HIGHLIGHT_STYLES[globbing]=fg=blue,bold
        ZSH_HIGHLIGHT_STYLES[history-expansion]=fg=blue,bold
        ZSH_HIGHLIGHT_STYLES[command-substitution]=none
        ZSH_HIGHLIGHT_STYLES[command-substitution-delimiter]=fg=magenta
        ZSH_HIGHLIGHT_STYLES[process-substitution]=none
        ZSH_HIGHLIGHT_STYLES[process-substitution-delimiter]=fg=magenta
        ZSH_HIGHLIGHT_STYLES[single-hyphen-option]=fg=magenta
        ZSH_HIGHLIGHT_STYLES[double-hyphen-option]=fg=magenta
        ZSH_HIGHLIGHT_STYLES[back-quoted-argument]=none
        ZSH_HIGHLIGHT_STYLES[back-quoted-argument-delimiter]=fg=blue,bold
        ZSH_HIGHLIGHT_STYLES[single-quoted-argument]=fg=yellow
        ZSH_HIGHLIGHT_STYLES[double-quoted-argument]=fg=yellow
        ZSH_HIGHLIGHT_STYLES[dollar-quoted-argument]=fg=yellow
        ZSH_HIGHLIGHT_STYLES[rc-quote]=fg=magenta
        ZSH_HIGHLIGHT_STYLES[dollar-double-quoted-argument]=fg=magenta
        ZSH_HIGHLIGHT_STYLES[back-double-quoted-argument]=fg=magenta
        ZSH_HIGHLIGHT_STYLES[back-dollar-quoted-argument]=fg=magenta
        ZSH_HIGHLIGHT_STYLES[assign]=none
        ZSH_HIGHLIGHT_STYLES[redirection]=fg=blue,bold
        ZSH_HIGHLIGHT_STYLES[comment]=fg=black,bold
        ZSH_HIGHLIGHT_STYLES[named-fd]=none
        ZSH_HIGHLIGHT_STYLES[numeric-fd]=none
        ZSH_HIGHLIGHT_STYLES[arg0]=fg=green
        ZSH_HIGHLIGHT_STYLES[bracket-error]=fg=red,bold
        ZSH_HIGHLIGHT_STYLES[bracket-level-1]=fg=blue,bold
        ZSH_HIGHLIGHT_STYLES[bracket-level-2]=fg=green,bold
        ZSH_HIGHLIGHT_STYLES[bracket-level-3]=fg=magenta,bold
        ZSH_HIGHLIGHT_STYLES[bracket-level-4]=fg=yellow,bold
        ZSH_HIGHLIGHT_STYLES[bracket-level-5]=fg=cyan,bold
        ZSH_HIGHLIGHT_STYLES[cursor-matchingbracket]=standout
    fi
else
    PROMPT='${debian_chroot:+($debian_chroot)}%n@%m:%~%# '
fi
unset color_prompt force_color_prompt
toggle_oneline_prompt(){
    if [ "$PROMPT_ALTERNATIVE" = oneline ]; then
    else
        PROMPT_ALTERNATIVE=oneline
    fi
    configure_prompt
    zle reset-prompt
zle -N toggle_oneline_prompt
bindkey ^P toggle_oneline_prompt
# If this is an xterm set the title to user@host:dir
case "$TERM" in
xterm*|rxvt*|Eterm|aterm|kterm|gnome*|alacritty)
    TERM_TITLE=$'\e]0;${debian_chroot:+($debian_chroot)}${VIRTUAL_ENV:+($(basename $VIRTUAL_ENV))}%n@%m: %~\a'
esac
precmd() {
    # Print the previously configured title
    print -Pnr -- "$TERM_TITLE"
    # Print a new line before the prompt, but only if it is not the first line
    if [ "$NEWLINE_BEFORE_PROMPT" = yes ]; then
        if [ -z "$_NEW_LINE_BEFORE_PROMPT" ]; then
            _NEW_LINE_BEFORE_PROMPT=1
        else
            print ""
        fi
    fi
# enable color support of ls, less and man, and also add handy aliases
if [ -x /usr/bin/dircolors ]; then
    test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)"
    alias ls='ls --color=auto'
    #alias dir='dir --color=auto'
    #alias vdir='vdir --color=auto'
    alias grep='grep --color=auto'
    alias fgrep='fgrep --color=auto'
    alias egrep='egrep --color=auto'
    alias diff='diff --color=auto'
    alias ip='ip --color=auto'
    export LESS_TERMCAP_mb=$'\E[1;31m'     # begin blink
    export LESS_TERMCAP_md=$'\E[1;36m'     # begin bold
    export LESS_TERMCAP_me=$'\E[0m'        # reset bold/blink
    export LESS_TERMCAP_so=$'\E[01;33m'    # begin reverse video
    export LESS_TERMCAP_se=$'\E[0m'        # reset reverse video
    export LESS_TERMCAP_us=$'\E[1;32m'     # begin underline
    export LESS_TERMCAP_ue=$'\E[0m'        # reset underline
    # Take advantage of $LS_COLORS for completion as well
    zstyle ':completion:*' list-colors "${(s.:.)LS_COLORS}"
    zstyle ':completion:*:*:kill:*:processes' list-colors '=(#b) #([0-9]#)*=0=01;31'
fi
# some more ls aliases
alias ll='ls -l'
alias la='ls -A'
alias l='ls -CF'
# enable auto-suggestions based on the history
if [ -f /usr/share/zsh-autosuggestions/zsh-autosuggestions.zsh ]; then
    . /usr/share/zsh-autosuggestions/zsh-autosuggestions.zsh
    # change suggestion color
    ZSH_AUTOSUGGEST_HIGHLIGHT_STYLE='fg=#999'
fi
# enable command-not-found if installed
if [ -f /etc/zsh_command_not_found ]; then
    . /etc/zsh_command_not_found
fi
Re: Z shell
MintPPC with the Z shell:
