Hello,
Is there a change with DOS-handler (task) termination with AmigaOS4.1Final ?
Because I always see the "DOS-handler 0.5 task" not finished when I quit (using " tasklist " command).
Before Final Edition my DOS-handler tasks quit nicely , but now they stay waiting... some clues ?
Thank you,
Regards,
DGILLES
DOS-handler completion with AmigaOS4.1Final
Re: DOS-handler completion with AmigaOS4.1Final
DOS-handler?
Not sure what that is.
These are the handlers running on my FE Update 2 system shortly after booting:
Anyway, what do you mean when you say "quit"? You don't expect to be able to use the WB menu to quit, do you?
This is not Windows - just turn off your machine
(after waiting a moment after any disk accesses).
> tasklist | grep handler
0x504544E0 process 5 waiting 65528 476 CON/con-handler 53.82
0x51FD60D0 process 5 waiting 65528 732 PIPE/queue-handler 53.4
0x5263DE30 process 5 waiting 65528 732 PIPE/queue-handler 53.4
0x521EC3A0 process 3 waiting 65528 316 TEXTCLIP/textclip-handler 53.4
0x521EC220 process 5 waiting 503800 16476 URL/launch-handler 53.39
0x5045E1F0 process 5 waiting 65528 476 CON/con-handler 53.82
0x50454C60 process 5 waiting 65528 476 CON/con-handler 53.82
0x50454AE0 process 5 waiting 65528 476 CON/con-handler 53.82
0x50733610 process 5 waiting 65528 476 CON/con-handler 53.82
0x50733310 process 5 waiting 65528 476 CON/con-handler 53.82
0x507F2D80 process 5 waiting 65528 476 CON/con-handler 53.82
0x507F2180 process 5 waiting 65528 476 CON/con-handler 53.82
0x51FD6B50 process 5 waiting 65528 476 CON/con-handler 53.82
0x521EC520 process 5 waiting 65528 316 APPDIR/appdir-handler 54.17
0x52C0D1A0 process 10 waiting 16376 700 RAM/ram-handler 54.24
0x52C0D320 process 5 waiting 32760 268 ENV/env-handler 54.18
0x52EE1A90 process 5 waiting 32760 476 CON/con-handler 53.82
0x52EE1910 process 5 waiting 32760 476 RAW/con-handler 53.82
0x52EE1790 process 5 waiting 32760 476 CON/con-handler 53.82
0x6FB8E4E0 process 19 waiting 16376 220 SFS DosList handler
0x6FD747D0 process 5 waiting 16376 252 dos_lock_handlerThis is not Windows - just turn off your machine
Hello,
Sorry it was not clear.
I wrote a DOS-handler named ACON,
So I see in the tasklist : ACON/DOS-handler 0.5 with AmigaOSFinal EditionU0.
But when my program, using this handler (which open it, close it), quit , I see the occurrence of tasks growing, so the ACON/DOS-handler 0.5 (task)process are always waiting.
I hope, it is better explained.
Thank you for your time.
Regards,
DGILLES
Regards,
DGILLES
Ah, I see.
That's not something I know much about - intuitively I'd think it would be your own code in the handler which should decide whether to shut down or stay waiting when no more callers are using it, but I don't know for sure.
Hopefully Colin sees this and has more solid info.
Thank you Niels,
Sometimes when I quit the program that have open my ACON handler, it crashes and There’s a pop-up saying :
Function : Wait_Until_Child_Ends
I suppose because I used NP_Child True when creating a process which shares data with the my ACON handler code.
But perhaps this is another issue with no matters with ACON/DOS-handler 0.5 task/process which won’t end up with my code with FinalEdition.
Because, ACON process tends to end before FinalEdition (4.1 update 0/1).
Hope Colin’s explain me what to do to solve.
DGILLES
DGILLES
- colinw
Without seeing your source code to look what you are doing, it's difficult to say exactly
what is causing your problem, however you did mentioned above;
When creating a process with NP_Child,TRUE the child ABSOLUTELY MUST exit before the parent can do so,
there needs to be robust exit arbitration put in place by the parent, so this always happens,
See IDOS->WaitForChildExit() and also IDOS->CheckForChildExit(), also the autodoc for IDOS->CreateNewProc()
has several code examples on how to do this on earlier DOS releases.
Secondly, you must not share data with any DOS handler process that does not come in via a dospacket
(or vector port function for new style filesystems)
All DOS handlers must be re-entrant, the same loaded code can be run by multiple processes concurrently,
so the handler process must open any resources itself and delete them on exit itself,
and the handler process is never flagged as an NP_Child when started by DOS.
You can only have READABLE global data that the handler process accesses, and WRITABLE data that is going
to be accessible between processes absolutely must be protected by a semaphore or mutex.
I am not sure why you are creating a process, but DOS takes care of starting up the handlers for you.
This happens automatically when something accesses the device name in the doslist.
Specifically when something calls the IDOS->GetDeviceProc[Flags] function.
So, please check the packet autodocs for ACTION_STARTUP, it will show the handler startup proceedure.
Other than the above, you can run the FSVPTool in SDK:c and look at the start.c function for example
code of starting up a new style filesystem handler, just ignore the vector-port stuff if you are doing
a dospacket based handler.
I hope this helps.
There's at least two problems with that sentence.I suppose because I used NP_Child True when creating a process which shares data with the my ACON handler code.
I hope this helps.
Hello @Niels @Colinw @Amigans
For the termination problem I used a Forbid() call just before the return 0; of my "other task".
And now the cumulative trouble of tasks DOS-handler not finishing is removed. Great !
For the child (i.e the "other task") to terminate before the parent ; that is not a good idea.
Because code must be multi core proof ! Other process can enter so I remove NP_Child, TRUE, and replace by NP_FreeSeglist, FALSE, finger crossed no more crash.
Now the forwarding question : how to REMOVE the DOS VOLUME AND ITS TASK ?
I use :
assign ACON: remove
Or
C:dismount ACON: force
But they remove the volume ACON: from the volume list visible by assign command alone but not the DOS-handler task.
Any idea ?
Afterwards I can use a : break process name ctrl_F, because my ACON: can terminate on Ctrl_F signal but this command do not found the process name… given : "ACON/DOS-handler 0.5"
Any idea ?
I will open another topic for : "display and key strokes" not stop on key up ; when using IIR VANILLA KEY or something like this with input.device or console.device
Topic for @tonyw
Best weekend to all
I use :
assign ACON: remove
Or
Any idea ?
Any idea ?
Topic for @tonyw
Best weekend to all
- colinw
IExec->Forbid() is -NOT- a valid process exit arbitration mechanism.gdridi wrote: Sat Jun 05, 2021 12:14 am Hello @Niels @Colinw @Amigans
IExec->Wait() breaks IExec->Forbid() and during a process cleanup, any internal DOS calls to
IDOS->Unlock() or IDOS->Close() for the default locks or streams can result in either a Wait()
from a DosPacket transaction or a Signal Semaphore(), so don't do it. !!!
There's no "fingers crossed" required if you do it properly.For the child (i.e the "other task") to terminate before the parent ; that is not a good idea.
Your plan to just leak the loaded segments memory away each time it starts and leave the child
process whizzing around in orphaned code forever, is wrong on so many levels and a dreadfull strategy.
Several actually;Now the forwarding question : how to REMOVE the DOS VOLUME AND ITS TASK ?
I use :
assign ACON: remove
Or
Any idea ?
1) ACON: is not an assignment, c:Assign is not going to help you.
2) Don't use the FORCE option for Dismount as an operational strategy, it leaks memory and is dangerous and
likely to crash the machine, please read the supplied documentation.
3) Write the handler properly so it exits automatically when the last lock/stream is released,
if that's how you want it to behave, or, have it start a new handler instance each time like CON:
(by not initialising dn_Port on startup, and exit upon Close() each time.)
I think you need to do some more research, a DOS handler is a bit ambitious.
Which SDK version number to find start.c ?colinw wrote: Fri Jun 04, 2021 2:06 am Without seeing your source code to look what you are doing, it's difficult to say exactly
I hope this helps.
Thereeafter, what the meaning of DosNode->dn_Task ?
* Causes a new process to be created on next reference
// DosNode->dn_Task = &DosProc->pr_MsgPort; ? WB error!
DosNode->dn_Task = FALSE;
//DosNode->dn_Task = 0L; // Pareil
I use the cat program, like cat <ACON: >ACON: creating only two (2) more ACON process-handler.
But the standard AmigaDOS: copy ACON: to ACON: creating me a lot more six (6) handlers ?
In addition to the two above.
Would you like to explain ? It is to AmigaDOS to close these extra handler copies?
For cat, we read angle brackets missing *>ACON: so this is clear, only input and output streams.
For copy, we suppose three input, output, output_error but two times (3 * 2 = 6).
Moreover the "classic" mines referenced ACON: ACON: two times ?
The best,
DGILLES
For DOS basics I still recommend the Guru Book http://babel.de/amiga.html#doc
Enjoy the power of ARexx http://aminet.net/package/gfx/conv/GPS2URL
