Probably already answered, but i couldn't find anything.
If i create a new directory on WB (without an icon) the fealt drawer icon will be used obviously.
But when i open said default drawer the winow will always be at the same position, far to the top left of my WB big screen.
Is there a possibility to change that default position?
def_drawer.info doesn't seem to hold any information about that, or maybe i'm not seeing it.
Any help appreciated
default drawer window postition
Re: default drawer window postition
It should. Of course you don't see it in icon information.Raziel wrote: Fri May 21, 2021 4:03 pm def_drawer.info doesn't seem to hold any information about that
The normal way to change the default window position is to create a new drawer, open it, position and snapshot the window and then copy the changed icon back to envarc:sys/def_drawer.info.
