SDK for AmigaOS3.2?
AlfredOne
SDK for AmigaOS3.2?
Post by AlfredOne »
When will the SDK for AmigaOS3.2 be available?
Amiga500 Kickstart1.3
AmigaONE X1000 - 2GB RAM
  • Radeon R9-280X 3GB
  • Radeon HIS4670 1GB DDR3
  • Radeon RX550
My site: https://project4a.eu
amifrog
Re: SDK for AmigaOS3.2?
Post by amifrog »
It is on the CD, including the changelog.
@amifrog
But it will be made available for free download later aswell, won't it?
amifrog
Post by amifrog »
Sure, why not? Probably from Hyperions downloads.
Awesome :-)
amifrog
Post by amifrog »
To be clear, it is only an NDK, not a SDK.
NinjaCyborg
Post by NinjaCyborg »
Yes I noticed that - new header files and libs, a few examples. But nothing like the full SDK OS4 offers (albeit the OS4 one is a bit out of date these days)
Still, I hope we get to a point where there is a standardised OS3 SDK, because nothing is more important for developer collaboration that having a common toolchain.
I'd like to see:
- a recent-ish 68K GCC and binutils build free from old geekgadgets dependencies
- clib2 and libnix included
- a common folder structure for SAS/C and VBCC to fit into so that one can easily switch compilers like on OS4
This might be completely utopic, but I'd like to see one SDK to rule them all.
One SDK for OS3 and OS4.
One SDK to maintain.
One SDK that determines on install which software/hardware to use and one that asks for which target(s) to compile.
Would make it easier to update too, I think.
One SDK that would (more or less) stay on the same level of up-to-dateness for both targets.
etc.
NinjaCyborg
The OS4 SDK is a good foundation for that, it just needs a bit of work to update it to the latest GCC and clib2 revisions, and to add in the 68K target support and NDK files. But then it will only run on OS4 so further work is needed to integrate that with linux cross compilers that third parties have put together, or even to make it run on OS3 (with limitations)
