Fresh uInitrds?
Fresh uInitrds?
Is there any newer uInitrd available than the 5.5-rc7...? It seems still to work but would it be possible to include automatically a fresh one with each 'finalized' kernel version ?-)
BTW, I'm very surprised if no one else here uses them...? It is MUCH easier to identify Linux partitions using their LABELs than with those cryptic UUID codestrings etc.!
Re: Fresh uInitrds?
Roland wrote: Wed Apr 28, 2021 9:59 am Is there any newer uInitrd available than the 5.5-rc7...? It seems still to work but would it be possible to include automatically a fresh one with each 'finalized' kernel version ?-)
Hi Roland,
You can compile it yourself. You can find instructions in the following screenshot:
Re: Fresh uInitrds?
xeno74 wrote: Thu Apr 29, 2021 3:48 pm You can compile it yourself. You can find instructions in the following screenshot:
Thanks! Got it compiled... But the first command gave some error messages:
$ sudo mkinitramfs -o initrd-5.12.img 5.12.0_A-EON_X5000
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8125b-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8125a-3.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168fp-3.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168h-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168h-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168g-3.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168g-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8106e-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8106e-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8411-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8411-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8402-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168f-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168f-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8105e-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-3.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168d-2.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168d-1.fw for built-in driver r8169
W: Possible missing firmware /lib/firmware/renesas_usb_fw.mem for built-in driver xhci_pci
W: Possible missing firmware /lib/firmware/emu/emu1010_notebook.fw for built-in driver snd_emu10k1
W: Possible missing firmware /lib/firmware/emu/emu0404.fw for built-in driver snd_emu10k1
W: Possible missing firmware /lib/firmware/emu/micro_dock.fw for built-in driver snd_emu10k1
W: Possible missing firmware /lib/firmware/emu/emu1010b.fw for built-in driver snd_emu10k1
W: Possible missing firmware /lib/firmware/emu/audio_dock.fw for built-in driver snd_emu10k1
W: Possible missing firmware /lib/firmware/emu/hana.fw for built-in driver snd_emu10k1
W: initramfs-tools configuration sets RESUME=UUID=6fa359ba-3deb-43d5-83df-6f1b8d05531f
W: but no matching swap device is available.
Are those serious - should they be corrected some way...?
Re: Fresh uInitrds?
Roland wrote: Thu Apr 29, 2021 10:23 pm
Please install the package linux-firmware.
Re: Fresh uInitrds?
xeno74 wrote: Fri Apr 30, 2021 8:00 am Please install the package linux-firmware.
There is no such package in the depot... (MintPPC). There is firmware-linux, but installing it did not eliminate the errors.
Re: Fresh uInitrds?
Roland wrote: Fri Apr 30, 2021 10:40 am
It's called linux-firmware in Ubuntu. I created a new uInitrd on ubuntu MATE 16.04.7 today.
Download: uInitrd-5.12
Re: Fresh uInitrds?
xeno74 wrote: Fri Apr 30, 2021 12:45 pm Download: uInitrd-5.12
Works without issues... Thanks!-)
Re: Fresh uInitrds?
Hi Roland,
I have released a new uInitrd for the stable longterm kernel 5.10. You can find it in the kernel 5.10.39 package.
Download: linux-image-5.10.39-X1000_X5000.tar.gz
I tested it very intensively and it works without any problems on my X5000.
Screenshot:
