mint linux x5000
Tijatjj
mint linux x5000
Post by Tijatjj »
hi where do you download the mint linux from, also the install stuff also thanks
Re: mint linux x5000
Tijatjj wrote: Sun Apr 18, 2021 1:46 am hi where do you download the mint linux from, also the install stuff also thanks
See this: viewtopic.php?p=51964#p51964
There is a link for downloading a working MintPPC partition image, and instructions how to copy it on your hard disk with dd. You may first need to create (with GParted) an empty partition of at least 10 000 MB on which you can then copy the MintPPC image. Please double check the correct partition name before using dd!-)
I suppose you have already Fienix installed...? You can boot MintPPC just like Fienix, using the same kernel components and Uboot variables. Just change the disk identifier to the MintPPC partition.
