Host, whois, traceroute on Fienix
gordini21
Post by gordini21 »
Hello,
I am trying to install these command on Fienix but with no success.
For host it is installed but i have some error.
the package for whois seems to be installed but not possible to install.
traceroute doesn't exist. all these command are installed by defaut on the latest ubuntu
any idea ?
thanks
Re: Host, whois, traceroute on Fienix
gordini21 wrote: Thu Mar 11, 2021 6:28 pm Hello,
any idea ?
thanks
Could you please post some error messages?
The bind9-host package provides the “host” command.
The package bind9-dnsutils provides the command "dig" and “nslookup”. You need also the packages "bind9-libs" and "libjson-c5" as dependencies.
whois is in the package “whois”.
