ipv6: MLD:
ipv6: MLD:
Hi
I got this error
ipv6: MLD: clamping QRV from 1 to 2 .
It stop the system to boot into graphical user interface .
someone who knows how to get rid of this error
Re: ipv6: MLD:
musa wrote: Sat Feb 13, 2021 3:33 pm Hi
I got this error
Which Linux distribution do you use? MintPPC? Did you upgrade it?
Re: ipv6: MLD:
xeno74 wrote: Sat Feb 13, 2021 5:19 pm
Hi
Fedora and Ubuntu remix 17. No problem with Debian or Mint
Re: ipv6: MLD:
Could you please check /etc/network/interfaces?
Re: ipv6: MLD:
xeno74 wrote: Sun Feb 14, 2021 8:38 am Could you please check /etc/network/interfaces?
Hi Christian
Fedora is built differently so I did not find the file there. In remix17 I found errors in / etc / network / interfaces and corrected them. Now the ipv6 error disappeared but I can not get remix17 to go into graphical inderface. I do not quite know what I'm doing with Fedora but I think I'm giving up remix17.
I found some commands that should disable ipv6 in Fedora
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
net.ipv6.conf.tun0.disable_ipv6 = 1
they must be in /rtc/sysctl.conf.
Then sudo sysctl -p
But there was no change for me.
Do you have a Fedora.img file if I choose to reinstall Fedora?
and maybe Remix17?
Many thanks for your help
Peter
Re: ipv6: MLD:
musa wrote: Sun Feb 14, 2021 12:37 pm In remix17 I found errors in / etc / network / interfaces and corrected them. Now the ipv6 error disappeared but I can not get remix17 to go into graphical inderface.
Here is the download for the latest Remix17: MATE_PowerPC_Remix_2017_0.9.1.img.tar.bz2
Download Size: 5.4 GB
MD5 Checksum: 5ccc3c1e7b59290cafa31cded931c6f1
If you have any issues with Xorg please delete the xorg.conf in /etc/X11 and try it again.
musa wrote: Sun Feb 14, 2021 12:37 pm Do you have a Fedora.img file if I choose to reinstall Fedora?
Here you are: fedora27.img.tar.gz
Download Size: 4.5 GB
MD5 Checksum: 1a818913c4a25932811af9ce9732d615
Re: ipv6: MLD:
hi Christian.
Tried deleting xorg.conf and also changing it without success.
The best is a flashing cursor. Now I am replacing both Fedora and Remix17.
Thank you for always being there to help.
Peter
