What is this new vsata.device that has appeared with Update 2?
In MediaToolbox, I have p50x0sata.device, which is the replacement for p5020sata.device, but I also have vsata.device. It appears to be my onboard sata but only sees the SSD (I don't know if it ignores removable media or just can't see the channel my DVD drive is on).
vsata.device
Re: vsata.device
It's just a part of the driver code which has been refactored out to a separate module. It contains code which is common to the X50x0 and the A1222.
