AMIdock DSI when switching composition OFF
Mrodfr
Post by Mrodfr »
Hello,
Opening the GUI setting program for disabling the composition mode (with default values) cause a DSI.
DSI saved, I use the restart AmigaOS and all the time, after the quick reboot, the first program, for example, MUI-OWB crash with a DSI also.
To see MUI-OWB working fine, I must do a switch ON/OFF of the computer.
See the DSI:
Crash log for task "AmiDock"
Generated by GrimReaper 53.2
Crash occured in module newlib.library.kmod at address 0x0164B1F4
Register dump:
0: 5FE44CAC 5A1DB430 00000000 00000025 5A086000 00000000 00000024 5FE44CD4
8: 5A585C88 5FE44CD4 000000A0 00000000 00000001 5BB2BF04 5A29A680 5A538ADC
16: 5A29A69C 5A29A690 5A29A688 5A29A678 59734290 5A29A67C 5BB20000 5BB20000
24: 00009C4C FFFFFFFE 000000A1 00000073 00000070 00000028 5A585CF8 5FE44C88
0: nan 873 742 0
4: 16 150.8 41.8 0
8: 16 2.78132e-309 150.8 41.8
12: 1024 768 3.92036e-308 0
16: 0 0 0 0
20: 0 0 0 0
24: 0 0 0 0
28: 0 0 -4.4883e-05 0
Machine State (msr) : 0x0002F030
Condition (cr) : 0x22422044
Instruction Pointer (ip) : 0x0164B1F4
Xtended Exception (xer) : 0x20000001
Count (ctr) : 0x01416BC8
Link (lr) : 0x0164A77C
DSI Status (dsisr) : 0x00800000
Data Address (dar) : 0x00000008
680x0 emulated registers:
DATA: 5B9BACAE 00000003 00000000 00000000 00000000 00000000 00000000 00000000
ADDR: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 5A1DB700
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x0164B1F4 belongs to module "newlib.library.kmod" (HUNK/Kickstart)
Stack trace:
native kernel module newlib.library.kmod+0x00011a54
native kernel module newlib.library.kmod+0x00007e80
module AmiDock at 0x6FAF0058 (section 5 @ 0x41038)
module AmiDock at 0x6FAF02B8 (section 5 @ 0x41298)
module AmiDock at 0x6FABBBE0 (section 5 @ 0xCBC0)
module AmiDock at 0x6FADA6A8 (section 5 @ 0x2B688)
module AmiDock at 0x6FABDE90 (section 5 @ 0xEE70)
module AmiDock at 0x6FAD4F00 (section 5 @ 0x25EE0)
module AmiDock at 0x6FAAFD64 (section 5 @ 0xD44)
module AmiDock at 0x6FAAFE44 (section 5 @ 0xE24)
module AmiDock at 0x6FADABB4 (section 5 @ 0x2BB94)
module AmiDock at 0x6FAAF510 (section 5 @ 0x4F0)
module AmiDock at 0x6FAB0E24 (section 5 @ 0x1E04)
module AmiDock at 0x6FAB1298 (section 5 @ 0x2278)
module AmiDock at 0x6FAB136C (section 5 @ 0x234C)
native kernel module newlib.library.kmod+0x00002054
native kernel module newlib.library.kmod+0x00002ce8
native kernel module newlib.library.kmod+0x00002e64
AmiDock:_start()+0x170 (section 1 @ 0x170)
native kernel module dos.library.kmod+0x00020a14
native kernel module kernel+0x0003af4c
native kernel module kernel+0x0003afcc
PPC disassembly:
0164b1ec: 91690008 stw r11,8(r9)
0164b1f0: 9167000c stw r11,12(r7)
*0164b1f4: 90eb0008 stw r7,8(r11)
0164b1f8: 912b000c stw r9,12(r11)
0164b1fc: 915f0008 stw r10,8(r31)
System information:
CPU
Model: AMCC PPC440EP V1.3
CPU speed: 666 MHz
FSB speed: 133 MHz
Extensions:
Machine
Machine name: Sam440EP
Memory: 524288 KB
Extensions: bus.pci
Expansion buses
PCI/AGP
00:00.0 Vendor 0x1014 Device 0x027F
00:0A.0 Vendor 0x12D8 Device 0x8150
00:0C.0 Vendor 0x1002 Device 0x4C66
Range 0: A8000000 - B0000000 (PREF.MEM)
Range 1: 00001000 - 00001100 (IO)
Range 2: B0000000 - B0010000 (MEM)
00:0E.0 Vendor 0x1095 Device 0x3114
Range 0: 00001100 - 00001108 (IO)
Range 1: 00001108 - 00001110 (IO)
Range 2: 00001110 - 00001118 (IO)
Range 3: 00001118 - 00001120 (IO)
Range 4: 00001120 - 00001130 (IO)
01:04.0 Vendor 0x1013 Device 0x6005
Range 0: A0000000 - A0001000 (MEM)
Range 1: A0010000 - A0020000 (MEM)
01:05.0 Vendor 0x1131 Device 0x1561
Range 0: A0020000 - A0021000 (MEM)
01:05.1 Vendor 0x1131 Device 0x1561
Range 0: A0021000 - A0022000 (MEM)
01:05.2 Vendor 0x1131 Device 0x1562
Range 0: A0022000 - A0022100 (MEM)
Libraries
0x5bf51218: french.language V52.1
0x01dbd7f6: exec.library V53.22
0x5ff62174: vilintuisup.library V0.9
0x5ff62048: cgxvideo.library V42.1
0x5ff6b0e0: cybergraphics.library V43.0
0x59b19540: palette.gadget V53.6
0x5fd21b40: getcolor.gadget V53.9
0x59b19400: gradientslider.gadget V53.5
0x59b192c4: colorwheel.gadget V53.5
0x59d65338: radiobutton.gadget V53.9
0x5a1b9ce8: cs4281.audio V5.5
0x5a2c1864: device.audio V6.2
0x59f95730: slider.gadget V53.12
0x5a568200: getfont.gadget V53.8
0x5a2e9b90: getfile.gadget V53.10
0x5a1b9dc8: clicktab.gadget V53.38
0x5a2e97d0: arexx.class V53.3
0x5a2e9690: checkbox.gadget V53.9
0x5a52e190: requester.class V53.18
0x5a2e9550: space.gadget V53.6
0x5fd21358: chooser.gadget V53.18
0x5a2e9410: penmap.image V53.5
0x5a2e9370: bitmap.image V53.9
0x5a2e92d0: integer.gadget V53.10
0x5fd21494: filesave.audio V6.3
0x5aed8448: listbrowser.gadget V53.49
0x5c1bdc50: string.gadget V53.16
0x5af285e0: scroller.gadget V53.11
0x5aecc1a8: emulation.library V41.446
0x5b6394e0: mathieeedoubbas.library V52.1
0x5b9ac5d4: usergroup.library V4.30
0x5b81ba60: bsdsocket.library V4.292
0x5b9bf92c: textclip.library V52.2
0x5be84a5c: xadmaster.library V13.1
0x5ba01378: usbhidgate.library V52.2
0x5ba00204: xpkmaster.library V5.2
0x5ff98dac: hid.usbfd V53.7
0x5bf189b0: button.gadget V53.14
0x5bf18af0: glyph.image V53.3
0x5bde6b40: window.class V53.42
0x5bf95158: popupmenu.class V53.2
0x5be0d098: popupmenu.library V53.5
0x5bf187d0: label.image V53.12
0x5ff629a8: layout.gadget V53.19
0x5bf95060: bevel.image V53.6
0x5bf18550: drawlist.image V53.3
0x5bf18050: png.datatype V53.6
0x5bde5674: picture.datatype V53.6
0x5bf053c4: asl.library V53.45
0x5c008c4c: ft2.library V53.1
0x5bed508c: workbench.library V53.37
0x5bf6e4e0: Picasso96API.library V2.356
0x5bef9b90: gadtools.library V53.4
0x5bfa84f8: timezone.library V53.6
0x5bf3e6b8: application.library V53.12
0x5fffbcac: commodities.library V53.1
0x5bff9140: datatypes.library V53.4
0x5c008954: png.iconmodule V53.1
0x5bfa10cc: icon.library V53.13
0x5fe16698: version.library V53.7
0x5c0e0ec0: iffparse.library V53.1
0x5ffb1ccc: locale.library V53.3
0x5ff8b41c: diskfont.library V53.4
0x5c1bf028: petunia.library V53.3
0x5ff98f18: diskcache.library V3.30
0x5fccb654: dos.library V53.76
0x5ff62444: usbprivate.library V53.11
0x5fe4f13c: massstorage.usbfd V53.13
0x5fe4f0a8: bootkeyboard.usbfd V52.3
0x5fe4f028: bootmouse.usbfd V53.1
0x5ff622fc: hub.usbfd V53.8
0x5ff6224c: usbresource.library V53.11
0x5ff8a658: hunk.library V53.4
0x5ff98354: elf.library V53.14
0x5ff924d0: intuition.library V53.32
0x5ff48150: rtg.library V41.4355
0x5ff9b820: ATIRadeon.chip V53.23
0x5ff9b7a4: PCIGraphics.card V53.1
0x5ff9d7a0: keymap.library V53.3
0x5ff88330: layers.library V53.6
0x5ffb0420: graphics.library V53.4
0x5ff8a184: nonvolatile.library V52.1
0x5ff9e318: newlib.library V53.18
0x5ff991ac: utility.library V53.3
0x5ff9d0a8: expansion.library V53.1
0x5b9bacae: rexxsyslib.library V45.7 (Legacy)
Devices
0x5ae0c404: ahi.device V6.6
0x5af67018: ppc440ep_eth.device V53.6
0x5be63344: diskimage.device V52.75
0x5ff99d10: usbsys.device V53.11
0x5ff8acd0: ehci.usbhcd V53.15
0x5ff8ac30: ohci.usbhcd V53.18
0x5ff8ab90: uhci.usbhcd V53.7
0x5ff8aa24: sii3114ide.device V53.8
0x5fffb628: console.device V53.1
0x5ff9a3f0: ramdrive.device V52.6
0x5ff9d9ec: input.device V53.3
0x5fffb314: keyboard.device V53.5
0x5ff9a2d0: timer.device V53.1
Tasks
DepthToFront (Waiting)
Stack: 0x5a03b004 - 0x5a04affc, pointer @ 0x5a04a9e0 (Cookie OK)
State: Process (Waiting)
ClickToFront (Waiting)
Stack: 0x5a126004 - 0x5a135ffc, pointer @ 0x5a135a80 (Cookie OK)
input.device (Waiting)
Stack: 0x5ff50000 - 0x5ff60000, pointer @ 0x5ff5ff00 (Cookie OK)
State: Task (Waiting)
SFS DosList handler (Waiting)
Stack: 0x5fc81004 - 0x5fc82ffc, pointer @ 0x5fc82f20 (Cookie OK)
USB stack (Waiting)
Stack: 0x5fe3f000 - 0x5fe43000, pointer @ 0x5fe42f20 (Cookie OK)
EHCI Controller Task Unit 0 (Waiting)
Stack: 0x5fdeb000 - 0x5fdf3000, pointer @ 0x5fdf2f20 (Cookie OK)
Signals: SigRec 0xbe009000, SigWait 0x00000000
OHCI Controller Task Unit 1 (Waiting)
Stack: 0x5fe0b000 - 0x5fe13000, pointer @ 0x5fe12f20 (Cookie OK)
Signals: SigRec 0xbc009000, SigWait 0x00000000
OHCI Controller Task Unit 0 (Waiting)
Stack: 0x5fe2f000 - 0x5fe37000, pointer @ 0x5fe36f20 (Cookie OK)
sii3114ide.device - chip 0 port 0 (Waiting)
Stack: 0x5feaf000 - 0x5feb7000, pointer @ 0x5feb6f20 (Cookie OK)
page_sweep (Waiting)
Stack: 0x5fe57004 - 0x5fe5effc, pointer @ 0x5fe5ee80 (Cookie OK)
sii3114ide.device - chip 0 port 1 (Waiting)
Stack: 0x5fe7f000 - 0x5fe87000, pointer @ 0x5fe86f20 (Cookie OK)
ppc440ep_eth Unit 0 (Waiting)
Stack: 0x5af4d004 - 0x5af5dffc, pointer @ 0x5af5df20 (Cookie OK)
Signals: SigRec 0xf6001000, SigWait 0x00000000
WORKBENCH (Waiting)
Stack: 0x5fc7b004 - 0x5fc7cffc, pointer @ 0x5fc7ceb0 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x5fd31004 - 0x5fd38ffc, pointer @ 0x5fd38ee0 (Cookie OK)
Signals: SigRec 0xe0000000, SigWait 0x00000100
HID Mouse (Waiting)
Stack: 0x5ba3d004 - 0x5ba4cffc, pointer @ 0x5ba4cf20 (Cookie OK)
ICD0 (Waiting)
Stack: 0x5b6de004 - 0x5b6edffc, pointer @ 0x5b6edf20 (Cookie OK)
ICD1 (Waiting)
Stack: 0x5b76a004 - 0x5b779ffc, pointer @ 0x5b779f20 (Cookie OK)
RAM (Waiting)
Stack: 0x5c18c004 - 0x5c193ffc, pointer @ 0x5c193c90 (Cookie OK)
CD0 (Waiting)
Stack: 0x5fc87004 - 0x5fc88ffc, pointer @ 0x5fc88f20 (Cookie OK)
reaper.task (Waiting)
Stack: 0x5c0c0004 - 0x5c0c7ffc, pointer @ 0x5c0c7ea0 (Cookie OK)
dos_filedir_notify (Waiting)
Stack: 0x5fcaf004 - 0x5fcb2ffc, pointer @ 0x5fcb2ae0 (Cookie OK)
Signals: SigRec 0x10000000, SigWait 0x00000000
UTILS (Waiting)
Stack: 0x5fc8d004 - 0x5fc8effc, pointer @ 0x5fc8eeb0 (Cookie OK)
DONNEES (Waiting)
Stack: 0x5c6a2004 - 0x5c6a3ffc, pointer @ 0x5c6a3eb0 (Cookie OK)
CACHES (Waiting)
Stack: 0x5c69c004 - 0x5c69dffc, pointer @ 0x5c69deb0 (Cookie OK)
ARCHIVES (Waiting)
Stack: 0x5c696004 - 0x5c697ffc, pointer @ 0x5c697eb0 (Cookie OK)
DIVERS (Waiting)
Stack: 0x5c690004 - 0x5c691ffc, pointer @ 0x5c691eb0 (Cookie OK)
JEUX (Waiting)
Stack: 0x5fc93004 - 0x5fc94ffc, pointer @ 0x5fc94eb0 (Cookie OK)
MainIPC0 (Waiting)
Stack: 0x5ba59004 - 0x5ba68ffc, pointer @ 0x5ba68eb0 (Cookie OK)
Signals: SigRec 0x40000100, SigWait 0x00000000
hid.usbfd (Waiting)
Stack: 0x5baa1004 - 0x5baa8ffc, pointer @ 0x5baa8ee0 (Cookie OK)
HID Consumer (Waiting)
Stack: 0x5b9cc004 - 0x5b9dbffc, pointer @ 0x5b9dbf20 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x5baad004 - 0x5bab4ffc, pointer @ 0x5bab4ee0 (Cookie OK)
HID Keyboard (Waiting)
Stack: 0x5ba1d004 - 0x5ba2cffc, pointer @ 0x5ba2cf20 (Cookie OK)
Signals: SigRec 0x90001000, SigWait 0x00000000
HID Mouse (Waiting)
Stack: 0x5b9e8004 - 0x5b9f7ffc, pointer @ 0x5b9f7f20 (Cookie OK)
pager (Waiting)
Stack: 0x5c062004 - 0x5c081ffc, pointer @ 0x5c081f00 (Cookie OK)
ENV (Ready)
Stack: 0x5c03a004 - 0x5c03bffc, pointer @ 0x5c03bda0 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0x80000100
State: Process (Ready)
IDF0 (Waiting)
Stack: 0x5b79e004 - 0x5b7adffc, pointer @ 0x5b7aded0 (Cookie OK)
Signals: SigRec 0xa8000100, SigWait 0x00000000
IDF1 (Waiting)
Stack: 0x5b7f3004 - 0x5b802ffc, pointer @ 0x5b802ed0 (Cookie OK)
IDF2 (Waiting)
Stack: 0x5b844004 - 0x5b853ffc, pointer @ 0x5b853ed0 (Cookie OK)
IDF3 (Waiting)
Stack: 0x5b891004 - 0x5b8a0ffc, pointer @ 0x5b8a0ed0 (Cookie OK)
IPC0 (Waiting)
Stack: 0x5ba75004 - 0x5ba84ffc, pointer @ 0x5ba84ee0 (Cookie OK)
Signals: SigRec 0x00010100, SigWait 0x00000000
RANDOM (Waiting)
Stack: 0x5b017004 - 0x5b026ffc, pointer @ 0x5b026ef0 (Cookie OK)
URL (Waiting)
Stack: 0x5b04c004 - 0x5b0c6ffc, pointer @ 0x5b0c2a90 (Cookie OK)
CON (Waiting)
Stack: 0x5a4d6004 - 0x5a4e5ffc, pointer @ 0x5a4e5ed0 (Cookie OK)
KingCON DOS-process (Waiting)
Stack: 0x5a0bb004 - 0x5a0caffc, pointer @ 0x5a0caec0 (Cookie OK)
CON (Waiting)
Stack: 0x5a5ff004 - 0x5a60effc, pointer @ 0x5a60eed0 (Cookie OK)
CON (Waiting)
Stack: 0x5a674004 - 0x5a683ffc, pointer @ 0x5a683ed0 (Cookie OK)
Stack: 0x5a646004 - 0x5a655ffc, pointer @ 0x5a655ec0 (Cookie OK)
Stack: 0x5a5e1004 - 0x5a5f0ffc, pointer @ 0x5a5f0ec0 (Cookie OK)
CON (Waiting)
Stack: 0x5a6f0004 - 0x5a6ffffc, pointer @ 0x5a6ffed0 (Cookie OK)
Stack: 0x5a6b2004 - 0x5a6c1ffc, pointer @ 0x5a6c1ec0 (Cookie OK)
AUDIO (Waiting)
Stack: 0x5b8e6004 - 0x5b8f5ffc, pointer @ 0x5b8f5ec0 (Cookie OK)
CON (Waiting)
Stack: 0x5c140004 - 0x5c147ffc, pointer @ 0x5c147de0 (Cookie OK)
RAW (Waiting)
Stack: 0x5c198004 - 0x5c19fffc, pointer @ 0x5c19fde0 (Cookie OK)
CON (Waiting)
Stack: 0x5c1b4004 - 0x5c1bbffc, pointer @ 0x5c1bbde0 (Cookie OK)
dos_nbmd_process (Waiting)
Stack: 0x5ff20004 - 0x5ff21ffc, pointer @ 0x5ff21f20 (Cookie OK)
dos_lock_handler (Waiting)
Stack: 0x5ff1a004 - 0x5ff1bffc, pointer @ 0x5ff1bf00 (Cookie OK)
console.device (Waiting)
Stack: 0x5ff00000 - 0x5ff08000, pointer @ 0x5ff07f70 (Cookie OK)
Signals: SigRec 0xf0000000, SigWait 0x00000000
RexxMaster [] (Waiting)
Stack: 0x5ae79004 - 0x5ae88ffc, pointer @ 0x5ae88f50 (Cookie OK)
Stack: 0x5b6af004 - 0x5b6c2ffc, pointer @ 0x5b6c2c30 (Cookie OK)
Stack: 0x5b73b004 - 0x5b74effc, pointer @ 0x5b74ec30 (Cookie OK)
Stack: 0x5b786004 - 0x5b799ffc, pointer @ 0x5b799c30 (Cookie OK)
diskimage.device unit 1 (Waiting)
Stack: 0x5b7d3004 - 0x5b7e6ffc, pointer @ 0x5b7e6c30 (Cookie OK)
diskimage.device unit 2 (Waiting)
Stack: 0x5b82c004 - 0x5b83fffc, pointer @ 0x5b83fc30 (Cookie OK)
diskimage.device unit 3 (Waiting)
Stack: 0x5b879004 - 0x5b88cffc, pointer @ 0x5b88cc30 (Cookie OK)
diskimage.device unit 6 (Waiting)
Stack: 0x5b91c004 - 0x5b92fffc, pointer @ 0x5b92fc30 (Cookie OK)
TEXTCLIP (Waiting)
Stack: 0x5b908004 - 0x5b917ffc, pointer @ 0x5b917eb0 (Cookie OK)
ToolsDaemon [ToolsDaemon] (Waiting)
Stack: 0x59e3a004 - 0x59e49ffc, pointer @ 0x59e49f70 (Cookie OK)
Signals: SigRec 0xe0000000, SigWait 0x00000000
Workbench [Workbench] (Ready)
Stack: 0x5ae1c004 - 0x5ae2bffc, pointer @ 0x5ae2bea0 (Cookie OK)
ramlib (Waiting)
Stack: 0x5c086004 - 0x5c09effc, pointer @ 0x5c09ef20 (Cookie OK)
ContextMenus Command Dispatcher [ContextMenus Command Dispatcher] (Waiting)
Stack: 0x5a203004 - 0x5a212ffc, pointer @ 0x5a212f40 (Cookie OK)
Stack: 0x5ad75004 - 0x5ad84ffc, pointer @ 0x5ad84f40 (Cookie OK)
Stack: 0x5a2fa004 - 0x5a309ffc, pointer @ 0x5a309db0 (Cookie OK)
Stack: 0x5add3004 - 0x5ade2ffc, pointer @ 0x5ade2f00 (Cookie OK)
RinghioServer (Ready)
Stack: 0x5a4f4004 - 0x5a513ffc, pointer @ 0x5a513370 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x10000100
TCP/IP Control (Ready)
Stack: 0x5afa7004 - 0x5afb6ffc, pointer @ 0x5afb6dc0 (Cookie OK)
Signals: SigRec 0xf8009080, SigWait 0x40000100
DH3 (Waiting)
Stack: 0x5b65d004 - 0x5b66cffc, pointer @ 0x5b66cf60 (Cookie OK)
Signals: SigRec 0xd0000100, SigWait 0x00000000
« IPrefs » (Waiting)
Stack: 0x5bf73004 - 0x5bf82ffc, pointer @ 0x5bf82530 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x00000100
ContextMenus [] (Waiting)
Stack: 0x5a0d9004 - 0x5a0e8ffc, pointer @ 0x5a0e8c50 (Cookie OK)
Signals: SigRec 0xe0001000, SigWait 0x00000100
ASYNCWB (Waiting)
Stack: 0x5a18f004 - 0x5a19effc, pointer @ 0x5a19ee70 (Cookie OK)
RAWBInfo (Waiting)
Stack: 0x5a153004 - 0x5a162ffc, pointer @ 0x5a162ec0 (Cookie OK)
DefIcons (Waiting)
Stack: 0x5a173004 - 0x5a182ffc, pointer @ 0x5a182dc0 (Cookie OK)
ConClip (Waiting)
Stack: 0x5aee5004 - 0x5aef4ffc, pointer @ 0x5aef4eb0 (Cookie OK)
Stack: 0x5afdf004 - 0x5afeeffc, pointer @ 0x5afeede0 (Cookie OK)
Signals: SigRec 0xf8003000, SigWait 0x00000100
TCP/IP Superserver [TCP/IP Superserver] (Waiting)
Stack: 0x5afc3004 - 0x5afd2ffc, pointer @ 0x5afd2a00 (Cookie OK)
Signals: SigRec 0xd0000080, SigWait 0x00000100
TCP/IP Log (Waiting)
Stack: 0x5affb004 - 0x5b00affc, pointer @ 0x5b00af00 (Cookie OK)
USB stack Process (Waiting)
Stack: 0x5bb09004 - 0x5bb18ffc, pointer @ 0x5bb18ee0 (Cookie OK)
datatypes.library (Waiting)
Stack: 0x5bd30004 - 0x5bd3fffc, pointer @ 0x5bd3ff10 (Cookie OK)
DST watcher (Waiting)
Stack: 0x5bee9004 - 0x5bef8ffc, pointer @ 0x5bef8f20 (Cookie OK)
Stack: 0x5bf17000 - 0x5bf17fa0, pointer @ 0x5bf17f10 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x5fd8f004 - 0x5fd96ffc, pointer @ 0x5fd96f00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x5fd9b004 - 0x5fda2ffc, pointer @ 0x5fda2f00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x5fd83004 - 0x5fd8affc, pointer @ 0x5fd8af00 (Cookie OK)
AmiDock (Crashed)
Stack: 0x5a1cc004 - 0x5a1dbffc, pointer @ 0x5a1db430 (Cookie OK)
Signals: SigRec 0x7f40d000, SigWait 0x00400100
State: Process (Crashed)
ramlib.support (Waiting)
Stack: 0x5c0a3004 - 0x5c0bbffc, pointer @ 0x5c0bbf00 (Cookie OK)
Signals: SigRec 0x80005000, SigWait 0x00000100
dos_signal_server (Waiting)
Stack: 0x5ff26004 - 0x5ff27ffc, pointer @ 0x5ff27f10 (Cookie OK)
Signals: SigRec 0x0000e000, SigWait 0x00000000
Picasso96 (Waiting)
Stack: 0x5bf2e004 - 0x5bf3dffc, pointer @ 0x5bf3dda0 (Cookie OK)
dos_appdir_server (Waiting)
Stack: 0x5ff2c004 - 0x5ff2dffc, pointer @ 0x5ff2dd40 (Cookie OK)
idle.task (Ready)
Stack: 0x5ff89000 - 0x5ff8a000, pointer @ 0x5ff89fd0 (Cookie OK)
State: Task (Ready)
