The topic i had 9 years ago with sudden restarts are always there. But i have to live with this.
The Amiga Sam440ep hangs on an KVM-Switch, so i can use my Windows PC and the Sam with one mice, keyboard and monitor. I think this could be one possible source of error.
Another thought i had was my harddrive with possible failures. So i started to try to reinstall the AmigaOS4.1FE on a "new" harddrive, but here began the nightmare.
As i connected the new harddrive (3,5" Samsung) and powered the Sam on, it was impossible to get it started. The power led showed for half a second the light but than powered off. The screen showed nothing, no UBoot screen, the time was so short that i even could not open the DVD drive with the button.
So i tried another Notebook Drive and a 240 GB SSD drive, but there was the same.
The fact is when i start the Sam with the original harddrive and connect these other drive via a sata->usb cable, AmigaOS shows the drive, i can get access via the media toolbox, install the slb, create partitions, etc. After i boot the Sam with the original AmigaOS 4.1FE-CD i can install the OS via the installed sata->usb option. But after disconnecting the old harddrive and connecting the new drive there is the same scenario that after pressing the power button the led lights and powers off instantly.
I had a fourth one hard drive, but this had a bad S.M.A.R.T. so i did not wanted to invest time to get the OS installed on there. But i tried the following and this is really strange for me! After connecting the power cable from the board to this drive (only the power cable!) but without connecting the sata cable the Sam powers on, provided the install CD is in the DVD drive.
When i try this with the other "new" drives it does not function.
So is my question, if a "sata drive is not equal to a sata drive"? Are there tensions or reistance a harddrive must have to work with the Sam? Or is the Sil-controller defective? Is than there a chance for a workaround?
My fear is that one day the now installed harddrive will get killed and i cannot get the AmigaOS installed on a new harddrive.
I posted my question also to Acube but did not get a response.
So i would appreciate any hint.
