Hi
I have found that the update2 kickstart even after the hotfix does not make the Swap work. Filling the Fast Ram the system crashes and does not fill the virtual memory. Trying RTCW after loading the initial menu, the message that cannot use VM is displayed. I have two 128MB Sims for a total of 256MB. Replaced Only the Update 1 kickstart and with the original CD Kernel works.
Amiga OS4.1fe update2 hotfix on BlizzardPPC
Discovery69
Re: Amiga OS4.1fe update2 hotfix on BlizzardPPC
The Swap is just broken as it was all the time, and working by the luck.
So better to not use it ever. It never does what is expected to.
Is that true in general or just for classic?
Discovery69
It true in generale, i Also have a Sam460 and when selling the memory It's crash. But with the Classic i use the swap , with the Sam usually i don't use it.
I'll make a video to explain the problem and i'll link it here.
Discovery69
Discovery69 wrote: Fri Jan 22, 2021 10:27 am It true in general, i Also have a Sam460 and when filling the memory It's crash. But with the Classic i use the swap , with the Sam usually i don't use it.
Discovery69
Hello below you will find the link of my video explaining the problem, also read the description for the characteristics of my Amiga 1200 PPC: https://youtu.be/iQel9Dm14yk
Discovery69
Hello below you will find the link of my video explaining the problem, also read the description for the characteristics of my Amiga 1200 PPC: https://youtu.be/iQel9Dm14ykkas1e wrote: Thu Jan 21, 2021 6:40 am The Swap is just broken as it was all the time, and working by the luck.
Discovery69
Here the link of the Return to Castle Test with Update 2 and hotfix , and Update 1 with the kernal of the Original CD:
https://youtu.be/psO16rcZ6mo
Well, the update is so evil that it actually replaces your startup-sequence, though it keeps the old startup-sequence as a backup. There you may notice that a magic string you had manually entered to the bootloader has been removed in the "updated" startup-sequence... all you have to to, is to add it back.Discovery69 wrote: Mon Jan 18, 2021 11:15 pm Hi
EDIT: or... am I misunderstanding something, you're saying that enabling swap works, but using it causes crash? If so... sorry for my useless attempt to be helpful
Discovery69
yes I noticed that the Startup-sequence is modified, in fact the pcmcia-wifi card no longer worked because the initialisation command had been removed.kolla wrote: Mon Jan 25, 2021 9:49 amWell, the update is so evil that it actually replaces your startup-sequence, though it keeps the old startup-sequence as a backup. There you may notice that a magic string you had manually entered to the bootloader has been removed in the "updated" startup-sequence... all you have to to, is to add it back.Discovery69 wrote: Mon Jan 18, 2021 11:15 pm Hi
EDIT: or... am I misunderstanding something, you're saying that enabling swap works, but using it causes crash? If so... sorry for my useless attempt to be helpfulI will try to fill up RAM on my A3000 and see what happens.
Are you telling me that there should be a swap-enabling string in the startup-sequence that may have been deleted after Update 2?
Or did I get it wrong?
Yes, however, if you look at the two videos that I linked you will see that with update 1 the swap works, with update 2 even after the hotfix does not go anymore. Even RTCW no longer works as seen in the second video, it returns a clear message that it is unable to merge the Virtual Memory.
