Mui x5000
Tijatjj
Mui x5000
Post by Tijatjj »
Hi have problem with MUI 5.Where would I be able to get fresh copy. Need to reinstall getting errors on lines (500 etc).I have OS install and Ehancer up to version 1.5
Also looking at updates tells me Radeon RX not found Is that usual for the enhancer or is that
For the graphic version that would need to be purchased.Thanks
Tijatjj
Re: Mui x5000
Post by Tijatjj »
Ok so it says object in use for mui ? Also I have license key full registration
smf
Re: Mui x5000
Post by smf »
For MUI you might need to close all MUI apps before installing it.
Or even maybe do a reboot and then install it before starting any MUI apps.
Tijatjj
Re: Mui x5000
Post by Tijatjj »
Thank you by the way no problems with update 2 with anything really except the clock oversized.Nice Work
Re: Mui x5000
Just reinstall the clock using updater... and the size issue is solved.
Re: Mui x5000
Just to make sure it is clear:
This will install the Enhancer Clock program back on top of the original Clock program of OS4. And when one day the OS version is again updated, it will again overwrite the third party Enhancer one.
Etc., etc.
Of course anyone is free to choose what suits them, but it would be beneficial if the choice was made on an informed basis.
