Kernel 5.11
Kernel 5.11
The Linux 5.11 merge window is open. :-) Happy testing!
Download: linux-image-5.11-alpha1-X1000_X5000.tar.gz
Amiguy
Re: Kernel 5.11
Post by Amiguy »
Hello Xeno
Up and running ;)
Re: Kernel 5.11
Amiguy wrote: Wed Dec 16, 2020 4:25 pm Hello Xeno
Up and running ;)
Great! Thank you for testing the alpha1! :-)
Re: Kernel 5.11
Kernel 5.11 Alpha1 up and running on my AmigaOne X5000
Big picture http://www.skateman.nl/wp-content/uploa ... 201941.png
Re: Kernel 5.11
Skateman wrote: Wed Dec 16, 2020 7:21 pm Kernel 5.11 Alpha1 up and running on my AmigaOne X5000
Re: Kernel 5.11
Re: Kernel 5.11
I got lazy and skipped alpha1 but attempts to run alpha2 get me
Did not find a cmdline Flattened Device Tree
Could not find valid device tree
What am I doing wrong?
Re: Kernel 5.11
kilaueabart wrote: Fri Dec 18, 2020 2:03 am I got lazy and skipped alpha1 but attempts to run alpha2 get me
It works with my X5000: /sys/firmware/devicetree/base
Did you load the device tree blob "cyrus-p5020.dtb" in U-Boot?
Re: Kernel 5.11
Here is the third alpha of kernel 5.11 for testing.
New: Linux 5.11 HID + Input Changes Bring Inhibiting Support, AMD Sensor Fusion Hub
Download: linux-image-5.11-alpha3-X1000_X5000.tar.gz
Re: Kernel 5.11
I compiled the latest Git kernel (alpha4) with the new PowerPC updates 5.11-1 today. Unfortunately this kernel doesn't boot on the X5000 and in a virtual e5500 QEMU machine anymore. The X1000 boots.
I was able to revert the new PowerPC updates 5.11-1 and after a new compiling, the kernel boots without any problems on my X5000.
git revert 8a5be36b9303ae167468d4f5e1b3c090b9981396 -m 1
I reported this issue to the Linuxppc-dev mailing list today.
Link: GIT kernel with the PowerPC updates 5.11-1 doesn't boot on a FSL P5040 board and in a virtual e5500 QEMU machine
I bisected today.
  1. Code: Select all
    git bisect start
  2. Code: Select all
    git bisect good 2c85ebc57b3e1817b6ce1a6b703928e113a90442
    (Good: Linux 5.10)
  3. Code: Select all
    git bisect bad a409ed156a90093a03fe6a93721ddf4c591eac87
    (Bad: Merge tag 'gpio-v5.11-1' -- 2020-12-17 18:07:20)
  4. git bisect good
  5. git bisect good
  6. git bisect good
  7. git bisect good
  8. git bisect bad
  9. git bisect bad
  10. git bisect bad
  11. git bisect good
  12. git bisect bad
  13. git bisect good
  14. git bisect good
  15. git bisect good
  16. git bisect bad
  17. git bisect bad
Result: d0e3fc69d00d1f50d22d6b6acfc555ccda80ad1e is the first bad commit
commit d0e3fc69d00d1f50d22d6b6acfc555ccda80ad1e
Author: Christophe Leroy <christophe.leroy@csgroup.eu>
Date:   Fri Nov 27 00:10:06 2020 +1100
    powerpc/vdso: Provide __kernel_clock_gettime64() on vdso32
    Provides __kernel_clock_gettime64() on vdso32. This is the
    64 bits version of __kernel_clock_gettime() which is
    y2038 compliant.
    Signed-off-by: Christophe Leroy <christophe.leroy@csgroup.eu>
    Link: https://lore.kernel.org/r/20201126131006.2431205-9-mpe@ellerman.id.au
:040000 040000 24e50126dc88b5fd2376be67d92b5e1930cd489f adbc4dcaf3cd78701b68bf873be105af135614e7 M	arch
git revert d0e3fc69d00d1f50d22d6b6acfc555ccda80ad1e
Output:
[master 3ced698f651c] Revert "powerpc/vdso: Provide __kernel_clock_gettime64() on vdso32"
 4 files changed, 18 deletions(-)
After a new compiling, the kernel boots without any problems.
I created a patch for reverting the bad commit:
diff -rupN a/arch/powerpc/include/asm/vdso/gettimeofday.h b/arch/powerpc/include/asm/vdso/gettimeofday.h
--- a/arch/powerpc/include/asm/vdso/gettimeofday.h	2020-12-19 00:01:16.825846606 +0100
+++ b/arch/powerpc/include/asm/vdso/gettimeofday.h	2020-12-19 00:00:38.213374736 +0100
@@ -187,8 +187,6 @@ int __c_kernel_clock_getres(clockid_t cl
 #else
 int __c_kernel_clock_gettime(clockid_t clock, struct old_timespec32 *ts,
 			     const struct vdso_data *vd);
-int __c_kernel_clock_gettime64(clockid_t clock, struct __kernel_timespec *ts,
-			       const struct vdso_data *vd);
 int __c_kernel_clock_getres(clockid_t clock_id, struct old_timespec32 *res,
 #endif
diff -rupN a/arch/powerpc/kernel/vdso32/gettimeofday.S b/arch/powerpc/kernel/vdso32/gettimeofday.S
--- a/arch/powerpc/kernel/vdso32/gettimeofday.S	2020-12-19 00:01:16.829846652 +0100
+++ b/arch/powerpc/kernel/vdso32/gettimeofday.S	2020-12-19 00:00:37.817369691 +0100
@@ -35,15 +35,6 @@ V_FUNCTION_BEGIN(__kernel_clock_gettime)
 	cvdso_call __c_kernel_clock_gettime
 V_FUNCTION_END(__kernel_clock_gettime)
- * Exact prototype of clock_gettime64()
- * int __kernel_clock_gettime64(clockid_t clock_id, struct __timespec64 *ts);
-V_FUNCTION_BEGIN(__kernel_clock_gettime64)
-	cvdso_call __c_kernel_clock_gettime64
-V_FUNCTION_END(__kernel_clock_gettime64)
  * Exact prototype of clock_getres()
diff -rupN a/arch/powerpc/kernel/vdso32/vdso32.lds.S b/arch/powerpc/kernel/vdso32/vdso32.lds.S
--- a/arch/powerpc/kernel/vdso32/vdso32.lds.S	2020-12-19 00:01:16.829846652 +0100
+++ b/arch/powerpc/kernel/vdso32/vdso32.lds.S	2020-12-19 00:00:38.209374686 +0100
@@ -118,7 +118,6 @@ VERSION
 		__kernel_get_syscall_map;
 		__kernel_gettimeofday;
 		__kernel_clock_gettime;
-		__kernel_clock_gettime64;
 		__kernel_clock_getres;
 		__kernel_time;
 		__kernel_get_tbfreq;
diff -rupN a/arch/powerpc/kernel/vdso32/vgettimeofday.c b/arch/powerpc/kernel/vdso32/vgettimeofday.c
--- a/arch/powerpc/kernel/vdso32/vgettimeofday.c	2020-12-19 00:01:16.829846652 +0100
+++ b/arch/powerpc/kernel/vdso32/vgettimeofday.c	2020-12-19 00:00:37.817369691 +0100
@@ -10,12 +10,6 @@ int __c_kernel_clock_gettime(clockid_t c
 	return __cvdso_clock_gettime32_data(vd, clock, ts);
-	return __cvdso_clock_gettime_data(vd, clock, ts);
 int __c_kernel_gettimeofday(struct __kernel_old_timeval *tv, struct timezone *tz,
