Hello!
Is it possible to run a PCI / PCIe USB card in the AmigaOne X5000?
My problem is that the Kryoflux will not work correctly on an USB hub.
PCI / PCIe USB Card workink with AmigaOne X5000
Re: PCI / PCIe USB Card workink with AmigaOne X5000
http://www.kryoflux.com/download/kf_quickstart.pdf
Simply don't use a USB-Hub.8. Attach the USB cable to KryoFlux and then attach it to your computer. Do not use a USB hub!
The AmigaOne X5000 have internal USB hubs. So all USB ports coming from the hub.
Do note that the thread ZeroG links to is quite old and only deals with AmigaOnes (SE, XE G3/G4 etc.).
I don't know for a fact whether the same cards will necessarily work in an X1000 or an X5000.
- Paul Zager
In my case, no. I had an NEC PCI USB2 card from my A1-XE that I tried to use when I first set up my X5000. It was not recognized.nbache wrote: Wed Oct 21, 2020 7:14 pm Do note that the thread ZeroG links to is quite old and only deals with AmigaOnes (SE, XE G3/G4 etc.).
Paul
A1-XE G4, 2GB, 9250
X5000/20
A1-XE G4, 2GB, 9250
X5000/20
