A new way to run Fienix (WIP)
daz
Post by daz »
Hi everyone,
In the past we had a live DVD for the X1000, for which we managed to simplify the install/booting, I've tried Fienix, and found it works well, but install/booting instructions are way more complicated than I like, so I've been trying to simplify things. I've now got something that some of you can test for me.
You'll need : an X5000 (/20 or /40) and a USB disk of 4G +
Downloadhttps://drive.google.com/file/d/1RghfKW ... sp=sharing
Unpack it to the root of the USB disk. (The disk doesn't need to be empty, but it helps)
To Boot:
Press a key once the bios anim starts, and select command line.
enter:
usb reset
when this has finished, enter
load usb 0 2000000 bootusb
the '0' may need to be changed, it will depend on how many usb disks you have attached. *DO NOT CHANGE THE 2000000!*
For X5000/20 enter
bootm 2000000
for X5000/40 enter
bootm 2000000#conf@2
A few minutes later a fienix boot screen will appear. I've used the same password for the fieniix user user as Casey does, and I've installed sudo.
Know issues:
The backdrop doesn't load. (Well it does when you boot as root.)
There is no persistant storage yet, the live-tools do support this, I will investigate soon
I've not created an easy install yet, should be just unpacking the root filesystem to media on the host machine - to be investigated.
Once we've confirmed this works for most people we can adjust what is installed.
Note:
This also boots on an X1000, (use zImage and initrd.gz) - the file x1kfienix is a script that contains the boot commands, but I had a lot of trouble with USB disks on my X1k, I couldn't get the script to run at all from USB, and often the kernel wouldn't load either.
Report results here please.
Darren
Re: A new way to run Fienix (WIP)
Hi Darren,
Thank you! I will try it.
Hi Darren,
I can confirm that your Fienix Live procedure as mentioned is working.
I have downloaded and extracted the files to a USB stick.
Booted, an Fienix Live is up and running.
My Onboard Ethernet adapter is not working in this version but does work in my on HDD installed Fienix version.
Anyway Great Work!!
Can't get the download, it requests a login.
daz
Post by daz »
nbache wrote: Tue Sep 29, 2020 11:18 pm Can't get the download, it requests a login.
It shouldn't do - I've set it to anyone with the link, can you try again.
Regards
Darren
Right, it's downloading now. I had to delete all cookies related to *google.* first.
Thanks.
Edit: Slowly, though ... around 350 kB/s |-). I'll check if it is done when I wake up. G'night!
Well, I succeeded in getting and unpacking the archive and write the unpacked files to a USB stick.
But I didn't get far when trying to use it on my X5000/40.
Entering "usb reset" into the UBoot command line gave me a crash.
Full boot and crash serial log:
(5 s
U-Boot molsen-2018-03-23 (Mar 23 2018 - 08:32:45)
CPU0:  P5040, Version: 2.1, (0x82040021)
Core:  e5500, Version: 1.2, (0x80240012)
Clock Configuration:
       CPU0:2200 MHz, CPU1:2200 MHz, CPU2:2200 MHz, CPU3:2200 MHz,
       CCB:800  MHz,
       DDR:800  MHz (1600 MT/s data rate) (Asynchronous), LBC:50   MHz
       FMAN1: 600 MHz
       FMAN2: 600 MHz
       QMAN:  400 MHz
       PME:   400 MHz
L1:    D-cache 32 KiB enabled
       I-cache 32 KiB enabled
Reset Configuration Word (RCW):
       00000000: 90e00000 00000000 acac9800 00440000
       00000010: 44808c00 ff29a000 68000000 61000000
       00000020: 00000000 00000000 00000000 0003000f
       00000030: a0000000 00000000 00000000 00000000
Board: CYRUS
36-bit Addressing
I2C:   ready
SPI:   ready
DRAM:  Initializing....using SPD
Detected UDIMM 99U5584-012.A00LF
Not enough bank(chip-select) for CS0+CS1 on controller 0, interleaving disabled!
There is no rank on CS0 for controller 1.
Not enough bank(chip-select) for CS0+CS1 on controller 1, interleaving disabled!
Not all controllers have compatible interleaving mode. All disabled.
2 GiB left unmapped
4 GiB (DDR3, 64-bit, CL=11, ECC off)
Local Bus Controller Registers
BR0xE0001001       OR0xFFF00010
BR0xE1001001       OR0xFFF00010
BR0x00000000       OR0x00000000
LBC0x40000000       LCR0x80010004
L2:    512 KiB enabled
Corenet Platform Cache: 2 MiB enabled
SERDES: bank 2 disabled
MMC:  FSL_SDHC: 0
Board Revision dead
MAC: 00:04:A3:6B:41:EE
MAC: 00:1E:C0:F7:D4:99
EEPROM: NXID v0
PCIe1: Root Complex, x4 gen2, regs @ 0xfe200000
  01:00.0     - 1002:67ff - Display controller
  01:00.1     - 1002:aae0 - Multimedia device
PCIe1: Bus 00 - 01
PCIe2: Root Complex, x4 gen2, regs @ 0xfe201000
  03:00.0     - 111d:8092 - Bridge device
   04:01.0    - 111d:8092 - Bridge device
    05:00.0   - 12d8:e111 - Bridge device
     06:04.0  - 1095:3112 - Mass storage controller
     06:05.0  - 1412:1724 - Multimedia device
   04:02.0    - 111d:8092 - Bridge device
    07:00.0   - 10ec:8168 - Network controller
   04:03.0    - 111d:8092 - Bridge device
   04:08.0    - 111d:8092 - Bridge device
   04:10.0    - 111d:8092 - Bridge device
PCIe2: Bus 02 - 0a
PCIe3: disabled
PCIe4: disabled
Looking for VGA
PINS: 0xfc000808
videoboot: Booting PCI video card bus 1, function 0, device 0
Begin BIOS POST
End BIOS POST
Setting VESA Mode
Found required VESA mode
About to set mode 279
About to get mode
Got mode 49431 (0xc117)
OK
XSize = 1024 YSize = 768 Base =0xe0000000
mmio_base = 0x80000000
bgx = 0xad55ad55 fgx = 0x0
In:    serial
Out:   serial
Err:   serial
SN: 116400037
UID: 4429431001910051bc17a080a0800000
Errata: ÿÿÿÿÿ'ÿ
Build date: 2016/04/27 14:11:14
CRC: 09b2278d
SCSI:  scanning bus for devices...
Found 0 device(s).
Net:   Initializing Fman
MMC read: dev # 0, block # 56985, count 128 ...
Fman1: Uploading microcode version 106.1.0
Fman2: Uploading microcode version 106.1.0
Tuning PHY @ 3
Tuning PHY @ 7
FM1@DTSEC5, FM2@DTSEC5
USB0:   USB EHCI 1.00
scanning bus 0 for devices... 5 USB Device(s) found
USB1:   USB EHCI 1.00
scanning bus 1 for devices... EHCI timed out on TD - token=0x80008c80
EHCI timed out on TD - token=0x80008d80
SATA0 (1.5 Gbps)
CE at device
       SATA1 (3 Gbps)
No medium present
  Device 0: (0:0) Vendor: TSSTcorp Prod.: CDDVDW SH-224DB Rev: SB00
            Type: Removable CD ROM
            Capacity: not available
Found 1 device(s).
X5000> usb reset
resetting USB...
USB not stopped: usbkbd still using USB
X5000> Machine check in kernel mode.
Caused by (from mcsr): mcsr = 0x00008000
NIP: 7FF569EC XER: 00000000 LR: 7FF569E8 REGS: 7fe2dc10 TRAP: 0200 DAR: 00000000
MSR: 00029200 EE: 1 PR: 0 FP: 0 ME: 1 IR/DR: 00
GPR00: 7FF569E8 7FE2DD00 7FE2DF00 00000000 7FF9EE72 7FE2EF28 00000038 00020000
GPR08: 00000800 7FFC5E40 00000000 7FE2DD00 7FF569D8 88A11454 00000000 7FFB0000
GPR16: 00000000 7FFB02C4 7FFB1728 7FFB172C 7FF971AA 00000000 7FF9718F 7FFA4724
GPR24: 00000001 7FFCD3D8 7FFCCE34 00000000 00000001 DEADBEEF 7FFA76E0 00000000
MCSR=0x00008000        MCSRR0=0x7ff569ec
MCSRR1=0x00029200MCAR=0x00000000
Call backtrace:
7FF569E8 7FF589D0 7FF58AAC 7FF3CD28 7FF3EC14 7FF401D4 7FF40410
7FF3D6FC 7FF3AEFC 7FF31650
Returning back to 0x7ff569ec
Call backtrace:
Skipping current instr, Returning to 0x7ff569f0
NIP: 7FF7ECA4 XER: 00000000 LR: 7FFA76E0 REGS: 7fe2db88 TRAP: 0200 DAR: 00000000
GPR00: 7FF7F1C0 7FE2DC78 7FE2DF00 DEADBEEF DEADBEEF 00000001 DEADBEEF DEADBEEF
GPR08: DEADBEEF 7FFC5E40 00000000 7FE2DD00 7FF569D8 88A11454 00000000 7FFB0000
GPR16: 00000000 DEADBEEF 7FFB1728 7FFB172C 7FF971AA DEADBEEF 7FF9718F DEADBEEF
GPR24: 00000001 00000001 DEADBEEF 00000000 DEADBEEF DEADBEEF 7FFA76E0 00000000
MCSR=0x00008000        MCSRR0=0x7ff7eca4
Call backtrace:
00000000 7FF7F1C0 7FF56A08 7FF589D0 7FF58AAC 7FF3CD28 7FF3EC14
7FF401D4 7FF40410 7FF3D6FC 7FF3AEFC 7FF31650
Skipping current instr, Returning to 0x7ff7eca8
NIP: 7FF531B0 XER: 00000000 LR: 7FF7ECAC REGS: 7fe2db88 TRAP: 0200 DAR: 00000000
GPR00: 7FF7F1C0 7FE2DC78 7FE2DF00 DEADBF8B 0000009C 00000001 DEADBEEF DEADBEEF
GPR08: DEADBEEF 00000080 00000000 7FE2DD00 7FF569D8 88A11454 00000000 7FFB0000
MCSR=0x00008000        MCSRR0=0x7ff531b0
Call backtrace:
Skipping current instr, Returning to 0x7ff531b4
NIP: 7FF56750 XER: 00000000 LR: 7FF56A10 REGS: 7fe2db60 TRAP: 0200 DAR: 00000000
GPR00: 7FF56A10 7FE2DC50 7FE2DF00 DEADBEEF 0000009C 00000001 DEADBEEF DEADBEEF
GPR08: DEADBEEF 00000003 00000000 7FE2DD00 7FF569D8 88A11454 00000000 7FFB0000
MCSR=0x00008000        MCSRR0=0x7ff56750
Call backtrace:
7FFB02C4 7FF56A10 7FF589D0 7FF58AAC 7FF3CD28 7FF3EC14 7FF401D4
Skipping current instr, Returning to 0x7ff56754
Caused by (from mcsr): mcsr = 0x0000a000
NIP: 7FF56758 XER: 00000000 LR: 7FF56A10 REGS: 7fe2db60 TRAP: 0200 DAR: 00000000
GPR08: DEADBEEF DEADBEEF 00000000 7FE2DD00 7FF569D8 88A11454 00000000 7FFB0000
MCSR=0x0000a000        MCSRR0=0x7ff56758
Call backtrace:
Skipping current instr, Returning to 0x7ff5675c
NIP: 7FF5679C XER: 00000000 LR: 7FF56A10 REGS: 7fe2db60 TRAP: 0200 DAR: 00000000
GPR24: 00000000 7FFCD3D8 7FFCCE34 00000000 00000002 DEADBEEF 7FFA76E0 00000000
MCSR=0x0000a000        MCSRR0=0x7ff5679c
Call backtrace:
Skipping current instr, Returning to 0x7ff567a0
NIP: 7FF567D0 XER: 00000000 LR: 7FF56A10 REGS: 7fe2db60 TRAP: 0200 DAR: 00000000
GPR00: 7FF56A10 7FE2DC50 7FE2DF00 DEADBEEF 00000000 00000001 DEADBEEF DEADBEEF
GPR08: DEADBEEF 7FFCCE36 00000000 7FE2DD00 7FF569D8 88A11454 00000000 7FFB0000
GPR24: 00000000 00000000 7FFCCE34 00000000 00000002 DEADBEEF 7FFA76E0 00000000
MCSR=0x0000a000        MCSRR0=0x7ff567d0
Call backtrace:
Skipping current instr, Returning to 0x7ff567d4
NIP: 7FF5679C XER: 00000000 LR: 7FF56820 REGS: 7fe2db60 TRAP: 0200 DAR: 00000000
GPR00: 7FF56A10 7FE2DC50 7FE2DF00 00000000 000000BE 00000000 00000001 00000000
GPR08: 00000004 00000000 7FFCCE34 7FE2DD00 7FF56820 88A11454 00000000 7FFB0000
GPR24: 00000000 00000002 7FFCCE34 00000000 00000003 DEADBEEF 7FFA76E0 00000000
Call backtrace:
NIP: 7FF567D0 XER: 00000000 LR: 7FF56820 REGS: 7fe2db60 TRAP: 0200 DAR: 00000000
GPR00: 7FF56A10 7FE2DC50 7FE2DF00 00000000 00000000 00000000 00000001 00000000
GPR08: 00000004 7FFCCE37 7FFCCE34 7FE2DD00 7FF56820 88A11454 00000000 7FFB0000
GPR24: 00000000 00000000 7FFCCE34 00000000 00000003 DEADBEEF 7FFA76E0 00000000
Call backtrace:
GPR00: 7FF56A10 7FE2DC50 7FE2DF00 00000000 000000EF 00000000 00000001 00000000
GPR24: 00000000 00000003 7FFCCE34 00000000 00000004 DEADBEEF 7FFA76E0 00000000
Call backtrace:
machine check count too high
### ERROR ### Please RESET the board ###
Hi Niels,
Could you please test it with another USB stick again? I have also issues with some USB sticks.
I'll see if I can find one.
Found an older stick, an 8 GB Gigaware. Same result.
The first one I tried was a new 256 GB SanDisk UltraFit.
But what I find interesting is that the dump after the usb reset command starts by saying:
---8<---
resetting USB...
---8<---
It sounds more like the USB system in UBoot is getting confused about the keyboard driver being there?
Did you also see that with the sticks you had problems with, Christian?
