AmigaOS 3.1.4 4000T Install disk hangs at FixRomLibs 45
ancalimon
Post by ancalimon »
I do not have the roms. I just bought 3.1.4 for testing. The first command "FixRomLibs 45" causes system to hang with mouse and caps lock locked.
I tried copying the 680x0 libraries to Libs: but that did not fix the issue. (I had to create a high density floppy first)
ancalimon
Re: AmigaOS 3.1.4 4000T Install disk hangs at FixRomLibs 45
Post by ancalimon »
Forgot to say this is solved. It was my fault. Had to wait sometime before powering on.
