Can the palette on browsers be adjusted to look normal?
Hypex
Post by Hypex »
Hi guys.
I just tested InterWeb, SpiderWeb and ArcticFox. I tried to post on AmigaWorld but the text and background are the same colour! That makes it near impossible to edit. I can only see it when drag selecting. I went into browser settings but they were limited with not much for colour. To my amazement a ten year old iBrowse is much more configurable in the palette department. :-P
Is it because AW is old and lacks full on CSS? The AW gadgets are all black and inverted looking as well. It's hard to tell as I'm using Fienix right now and it has a black desktop theme.
It looks okay here though and the text looks normal with black on white.
Re: Can the palette on browsers be adjusted to look normal?
Hypex wrote: Mon Jul 27, 2020 6:40 pm Hi guys.
Hi Hypex,
I have the same issue with InterWeb and Arctic Fox but with SpiderWeb I have black text on white background on Amigaworld.net (see screenshot below). I use the latest SpiderWeb version from the Fienix repository.
Screenshot:
Maybe it helps if you use an other theme with SpiderWeb.
Download: spiderweb-addons.zip
Hi Hypex,
Casey has solved the issue with the color of text and background. :-)
caseycullen wrote: Tue Aug 04, 2020 2:05 am InterWeb and SpiderWeb have been updated in the Fienix repositories for better theme consistency.
Arctic Fox has been added.
-Casey
Please update all browsers.
Hypex
Post by Hypex »
xeno74 wrote: Tue Aug 04, 2020 12:20 pm Hi Hypex,
That's good news. Thanks for the update. :-)
