SWAP RAM not active after clean 4.1FE install + update1 (Odyssey cannot start due to missing RAM)
Reth
Post by Reth »
Hi everybody,
I just wonder whether my SWAP partition might not be active for whatever reason? I did a clean install of 4.1FE + all updates.
Yesterday I installed latest Odyssey web browser but it cannot start since after starting it seems to load in the background until it tells me "Not enough memory" (A4000 with 128MB FAST RAM). So is there any chance to find the root cause and maybe run Odyssey on classic? Or can't it be used on classic at all?
Thank you in advance and
Kind Regards
Reth
Re: SWAP RAM not active after clean 4.1FE install + update1 (Odyssey cannot start due to missing RAM)
Post by Reth »
I did some further investigations:
Strangely I only get shown 126MB of overall virtual RAM size in WB title bar while I have 1GB in SWAP size partition.
Is this maybe due to the size of my physical FAST RAM? I have 128MB of fast RAM installed and WB title shows 126MB of overall FAST RAM.
This is really strange. Any ideas on that?
