USB device with multiple interfaces
AlfredOne
Post by AlfredOne »
Hello,
i'm writing a driver for a multitouch monitor.
The USB device has only 1 configuration with two interfaces:
- the 1st interface (ID = 0) is the multitouch interface with only 1 input endpoint (interrupt type with address 0x82)
- the 2nd interface (ID = 1) is the singletouch interface with only 1 input endpoint (interrupt type with address 0x81)
If i claim the 2nd interface i can receive singletouch packets from the endpoint 0x81.
If i claim the 1st interface i don't receive any packet from the endpoint 0x82.
The problem is the same both with a Function Driver, or with an Interface Driver.
Anyone has any idea why I am not getting messages from the 0x82 endpoint?
Thanks!
Amiga500 Kickstart1.3
AmigaONE X1000 - 2GB RAM
  • Radeon R9-280X 3GB
  • Radeon HIS4670 1GB DDR3
  • Radeon RX550
My site: https://project4a.eu
Belxjander
Re: USB device with multiple interfaces
Post by Belxjander »
Is it letting you select single vs multi touch support by which end-point you claim?
AlfredOne
Post by AlfredOne »
I observed this:
1) when i claim the Interface 0 and i request the HID Report Descriptor, i get an HID Report descriptor for a touchscreen with 10 touch points.
2) when i claim the Interface 1 and i request the HID Report Descriptor, i get an HID Report descriptor with only one touch point.
In the Interface descriptors i see that:
- interface 0 has the endpoint 0x82
- interface 1 has the endpoint 0x81
Both endpoints are of the same type (INPUT INTERRUPT) and with the same packet size (64 bytes).
So I thought that to receive multitouch events I had to claim interface 0 and then receive from its endpoint (0x82).
Is it possible that some type of standard HID request is needed to initialize access of the interface 0?
  • Radeon RX550
