Dynamically changing a label text
TomSoniq
Post by TomSoniq »
Hi!
I'd like to dynamically change the text in a label in both cases when the window containing that label is open and when it is closed (but the label object still exists).
From what I can see in the SDK examples, a label can have multiple elements. This means that a label can have multiple texts.
So when I just call
SetAttrs(labelobj, LABEL_Text, "Some text", TAG_END);
the behaviour seems to be undetermined. Sometimes it changes the only text that's in there, sometimes it adds another one.
This is understandable. How should it know what to do?
So the question is: How do I do it right? I've got a label object which already is the child of a textedit object. But this label object contains just a single text. Can I change that text? And if yes, how?
Tom
salass00
Re: Dynamically changing a label text
Post by salass00 »
The label class is not really meant to be dynamic so you might have trouble implementing that approach.
A more common way of having text that can be changed in a GUI is to use a button.gadget that is set to be transparent and borderless (no bevel) and then update its GA_Text with SetGadgetAttrs().
Post by thomasrapp »
salass00 wrote: Sun Mar 29, 2020 1:10 pm a button.gadget that is set to be transparent and borderless (no bevel)
... and read only :)
